Question about Home
Spa Pools, setting up spa pool with chemicals etc
Hi i have just brought i secound hand spa, i am woundering what sort of chemicals etc are required, there are no instuctions with it
    Novelist:
  • 171 Answers
Hi curlyall,
I'm Harvey the Master Plumber.
Your problem is: You have just brought a secound hand spa, you are woundering what sort of chemicals etc are required, there are no instuctions with it
If your spa is the type that you fill once, then you must treat it just like a swiming pool. Go to the local pool supplies store. They will be happy to set you up. Don't forget PH testing kit! Test it every day. And I prefer non chlorine chemicals. It's also helpfull to have a small submersible pump in case you need to replace the water sometime. Happy soaking!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 06, 2008
Winterizing spa
Not unless you want to drain it next season. There are special chemicals for use in pools and spas. Check on line and your area pool suppliers.
Dec 03, 2017 | Cars & Trucks
Tip
Keep your swimming pool water clear
Did you ever wonder how some pools stay so clear? Here is a tip that has worked for years with our family. We add three boxes of baking soda every month and only use a chlorine tablet in the floating tablet holder and thats it! Just pour the baking soda into the pool water. No other chemicals! The pool stays clear all summer long. Dont mess with all those chemicals! You will be saving money and making your pool duties much more simple. Try it. I promise you will be thanking me later :)
on Jul 07, 2011 | Pool & Spa
Can you leave an automatic pool cleaner in permanently
Not a good idea, unless it is a self-contained or using a separate pump, even then only run it when it's needed.The kind that use the pools circulation pump should only be used when needed. pool screened in ? use the cleaner 2 times a month for a few hours,
running a creepy crawler every time the pump comes on restricting the flow DRASTICLY reducing flow and will cause chemical imbalances eventually destroying the pools finish.-pump -filter ...
Jan 07, 2017 | Pool & Spa
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
chlorine
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
What can i use to get stains off my intex pure spa
metal control and get chemicals in balance
Oct 19, 2014 | Pool & Spa
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows:
chlorine 1.0 - 3.0 ideal
ph 7.4
alkalinity 100 ppm
calcium 200 ppm
stabilizer 50 ppm (saltwater pool 25 ppm)
These values will provide balanced swimming pool water
Jul 01, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Indoor swimming pool has bad smell only when running spa pump or ozone pump with lots of foaming
Hi.. I tell my customer to boil a glass jar and lid, like your canning. and use this jar to take the sample of water out of your pool - spa to have tested, take it to several places to have it tested.
and ozone pumps are not good to run inside in a open environment, I think the produce positive ions. but kill bacteria and odors, so if this is a SPA run the pump and ozone generator for a few days with the correct amount of anti foam and cover on it should clear right up. to avoid this problem pool and spas must have the pump on a timer or set to circulate !
if your not going to use your portable spa for say a season you must drain it !!! and drain the pumps. this will ensure that you get many many happy years of service out of your pumps and spa.
Hi; I'm Jay the pool pump motor repair guy in sunny longwood Florida. were the pool is always open, so jump in and get wet the waters just fine.
REMEMBER GREEN POOLS ARE DANGEROUS. children can fall in and not be seen costing valuable rescue time !!!
a clean pool is a safer pool "pool pump repair puppy"
Dec 29, 2012 | Pool & Spa
Home Logo
333 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
