Question about 2K Games Fantastic Four: Rise Of The Silver Surfer for Xbox 360
Xbox 360 overheating fan
My xbox 360 keeps getting double red light on the left hand side i know this is because of overheating and i think its because i knocked the fan when moving it - is there any way i can get to the fan to fix it.
  • jamesnapier May 12, 2009
    my xbox suddenly shut off mid game and 2 red lights showed up flashing red on the 1 and 3 controller sections. after some research i found out it meant that it was overheating. I wonder if everyday dust build up is causing it or if my fans are not running at top speed. i can feel warm air flowing out the back of the console but is it enough or is there another issue?
  • Anonymous Mar 30, 2014
    my Xbox 360 wont work when I press the power button. I think it is because my power supply unit is 100-225 voltage. I got my power supply brick from Africa which is the same power as Europe. I think that is to high for the United States power. Will my Xbox work if I get one made from here
  • 34 Answers
Http://www.youtube.com/watch?v=Uj2A7mGGjuY
That is a video that shows you how to open your xbox 360. It will void your warranty but I'm assuming its already void since you didn't send it in. If the fans running you should feel hot air coming out of the back of the xbox when its on.
Posted on Oct 07, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have the red ring of death
okay dont panic YET!
Try this try overheating ur xbox360 by stopping the fans ge 2 sticks small enogh to stop both fans i used two darts most people use q-tips well any way wen uv stopped ur fan s the red light s on ur xbox will still have 3 lights wait untill the lights have only 2 lit on the left hand side of the ring this is wen ur xbox will have overheated let it cook for 1min if that the unplug leave for 15-25mins to cool to room tempand boot it back up GREEN LIGHTS
Nov 27, 2010 | Microsoft Xbox 360 Console
Fixed the red ring of death, but now turn system on, the fan fires up slow to fast and then immediately quits and have 2 red lights on left side. What causes this?
2 red lights on the left side are overheating. I cant stress enough how much you dont want this to happen but if you want to order a new fan they have better fans. http://www.amazon.com/Talismoon-Whisper-Fan-Xbox-360-Blue/dp/B000H1V56U
if you need further assistance please let me know and i will be glad to help
Jun 01, 2010 | Microsoft Xbox 360 Console
Two red lights left side flashing on the xbox consol do you what what the solution is?
hello,
Two red lights lighting up means that your 360 is overheating... try to move your 360 to a cooler spot. you can also try to vent the heat by pointing a desk fan directly to the console.
I hope this helps.
- HotRatchet
Feb 11, 2010 | Microsoft Xbox 360 Console
While playing game the circle is green then lights up red
If your xbox is lighting up red on the player one and player sections( being the top left and bottome left) the problem is your xbox is overheating, u need to
a) if under warranty seek microsoft advice as your fans/cooling system may be faulty OR
b) pull apart and clean and test fans for functionabilty.Good Luck.
Nov 15, 2009 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
2 red lights on the left hand side. comes back on for 5-30 minutes then goes off red again.
Your xbox 360 console is overheating. Make sure all your vents are clean and unobstructed. Allow to cool for a few hours. If problem persistes you'll need to contact microsoft. May be an issue with the cooling fan
Oct 05, 2009 | Microsoft Xbox 360 Console
I just put a new case on my 360 and it has a clear pece that goes over the dvd drive so you can see the disc when i play for at leat 30 minuites the video cuts out the controoller continues vibrateing and...
left side, means thats your 2 red lights is your AV/HDMI cable not connected properly. 3 red lights is the ring of death. 4 red lights is the disk drive/laser has gone.
Aug 09, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
2K Games Fantastic Four: Rise Of The Silver Surfer for Xbox 360 Logo
726 people viewed this question
Top 2K Games Video Game Consoles & Games Experts
Tony
Are you a 2K Games Video Game Console and Game Expert? Answer questions, earn points and help others
