Question about Epson ACULASER CX11NF All-In-One Printer
Epson aculaser c1100 will not print from any of 3 computers on network
I get a message "check connections:is printer on:is printer online" I have changed the cable from router to printer, printer is on and online. I am able to print printer status at printer itself. I have reset the router and reloaded the software for the printer. I can connect to the internet via the router on all 3 computers.
  • Anonymous Mar 20, 2014
    the printer is connected to internet, I can se it in my computer but in status is idle
The IP number on each computer was wrong in one number, despite having printed for 20 months previously.
Posted on Oct 09, 2008
Epson c1100 showing 'offline'
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 10, 2011 | Epson Aculaser C1100 Printer
Epson AcuLaser changé photoconducteur et faire passer le message d'erreur «installer photoconductr"...et le photoconducteur pour ma nouvelle Epson Aculaser C1100 et je reçois le...
salut ;
ce message apparait lorsque le detecteur de photoconducteur est bloque avec du toner, desinstaller le photoconducteur ; nettoyer le detecteur situe a l'interieur.
Oct 19, 2010 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Feb 15, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
Install Photo Conductor
Perhaps, it is necessary to establish the necessary software.
http://filters.atspace.com
Aug 10, 2009 | Epson Aculaser C1100 Printer
I've a notice in epson aculaser 1100 lcd (service reg E511)
The E511 error for your Epson Aculaser  in most cases means that its motor has malfunctioned or something is preventing the motor from working properly.
Jan 26, 2009 | Epson Aculaser C1100 Printer
Communication error
HI-
How did you add the printer to your computer, try downloading the software for it. If there is any from support.epson.com site. check the port ID of the printer as well from printers and faxes then Epson properties and ports, it should be IP address for ports.
Hope this helps
Sep 30, 2008 | Epson Aculaser C1100 Printer
Epson C1100 Aculaser Duplex unit not recognised by Vista
I have had the problem, but it is easily fixed in Vista.
1. Click Control Panel
2 Click Printers
3 Right click your AL-C1100
4 Click Properties
5 Click Optional Settings label
6 Click - "Update printer info manually"
7 Click - "Duplex Print Unit "
8 Click Settings
9 Tick box in bottom left hand corner - "Duplex Print Unit"
10 Click OK .... exit
Sep 12, 2008 | Epson Aculaser C1100 Printer
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
