Lost of the sound
Since yesterday I lost the sound I am a user of windows vista E;INT(build 6000) navigateur Mozilla Firefox Client e.mail Windows Mail pare feu Kaspersky 7.0.0.125 Vista 3.1 (Processeur 4.7 memoire vive 4.2 graphique 3.4 SM Bios version 2.3 mon PC de marque FUTJITSU SIEMENS MS 7293VP 2.00 BIOS i Phoenix technologies LTD V2.0 11/14/2006 taille 512KB
sOUTH BRIDGE vIA vt 8237a barette de 1024 mo None
n.videa corporation ge force7500 LE (256mo)
After an uptade from Windows pack i lost my sound
help me please
Posted on Oct 06, 2008
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
Tip
Reset firefox
Resetting preferences
Actions
* Edit this page
* Translate this page
Show content customized for:
* Windows
* Linux
* Mac OS
* All
If you want to reset your Firefox preferences, this article provides instructions on how to reset them through Safe Mode.
To reset preferences:
1. Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Exit menu item.Close down Firefox completely: On the menu bar, click the Firefox menu, and select the Quit Firefox menu item.Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Quit menu item.
2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode).Hold down the Option key, as you start Firefox.Go to your Terminal and run:
firefox -safe-mode
You may need to specify the Firefox installation path (e.g. /usr/lib/firefox-3.5).
3. Firefox should start up with a Firefox Safe Mode dialog.
Note: You can also start Firefox in Safe Mode by clicking Start, selecting Run (or use the Start Search box in Windows 7 and Vista) and then entering the following in the text field:
firefox -safe-mode
4. To reset your user preferences, click to put a check mark by Reset all user preferences to Firefox defaults.
5. To apply your changes, click Make Changes and Restart.
Firefox will restart with your settings changed back to the defaults.
on Nov 19, 2013 | Mozilla Firefox
Tip
E-Mail on your PC and Mac!
An Introduction to Email Clients and Their Use at Home
A lot of us use an email client such as Outlook, Lotus Notes, or something similar at work. But many people don't realize there are programs (often for free) out there for you to use to catalog all of your email in the same manner right at home. You can have multiple email accounts, contact lists, a calendar, and a cache of other fun features which vary with each program. I will briefly touch on some of the similarities and differences between several of the clients. First, though, I will fill in those who don't know what the heck I am talking about so we are all on the same page.
So, introducing: The E-Mail Client! Email clients are programs locally installed on your computer that synchronizes with your email provider to deliver your email right to your PC or Mac without the need of navigating to their website and logging in. Often the common free providers like Hotmail, AOL, Yahoo, and Mac are auto-configured so you don't have to have information like POP, SMTP, and authentication types. These companies have made great efforts to streamline this process and make it as easy for the users as possible so that they can really enjoy their email. For example, Windows Vista users found a feature called Windows Mail that came for free on the OS. This is an email client! It prompts you for your name, username and password and then actually searches based on that information through its database to see if it can auto-configure your email. Mozilla Thunderbird does this as well. A newer and up and coming email client I have favored for a long time is Windows Live Mail. WLM is an upgrade to the Windows Mail that has a much more Outlook-like feel to it with a friendlier interface. It has your contact lists, calendar, and also integrates really well with your browser, Office applications, and graphics editing software. I really enjoy the cross compatibility and functionality this program provides. The next section will go more in depth into these programs.
Windows Mail
Windows Mail is a email client included with Windows Vista. Right off the bat, users can see that the client has been changed to better fit the look and feel of Vista. Also many features of MS Outlook 2003 such as the right reading pane. There are capable junk mail filters as well as a phishing filter, which helps protect unsuspecting users from websites and email that has been deemed dangerous. Windows Mail does not support HTTP clients such as AOL, Yahoo, and Google. Windows Live Mail or Mozilla Thunderbird would be a better option for these users . Lastly, the ability to use the spellchecking dictionaries of MS Office (when installed) has been removed. Windows Mail supports only a limited number of languages, listed below.
* English
* French
* German
* Spanish
Mozilla Thunderbird
Mozilla Thunderbird is a great email client that I am currently testing. It contains such new features as tabs, easier installation of add-ons, and better search functionality. One of the best features for wary users is the easier account creation by using the port auto detection for incoming and outgoing SMTP/POP Connections. This will be huge for users who would like to use this technology but don't want to be bothered with the technical programming. Thunderbird aims to be a simple e-mail, newsgroup and news feed client. Out of the box, Thunderbird does not come with a lot of calendar, contact lists, and other such functionality, but such things are available via extensions you can download from Mozilla. Thunderbird can manage multiple e-mail, newsgroup and news feed accounts and supports multiple identities within accounts. Features like quick search, saved search folders ("virtual folders"), advanced message filtering, message grouping, and labels help manage and find messages. On Linux-based systems, system mail (movemail) accounts are supported. Thunderbird runs on a wide variety of platforms. Releases available on the primary distribution site support the following operating systems:
* Windows
* Linux
* Mac OS X
* OS/2 [9]
* eComStation
* OpenSolaris
Thunderbird provides enterprise and government-grade security features such as SSL/TLS connections to IMAP and SMTP servers. It also offers native support for S/MIME secure email (digital signing and message encryption using certificates). Any of these security features can take advantage of smartcards with the installation of additional extensions.
Windows Live Mail
Windows Live Mail has all of the features of Windows Mail along with some new tricks of its own! Support for Web-based e-mail accounts including Windows Live Hotmail, Gmail/Google Mail, and Yahoo! Mail Plus being the biggest addition. It uses the multi-line message list like Outlook and you can use Emoticons and similar features. Live Mail also includes spell check. One of the best features, in my opinion, is that the different email accounts have different folders so there is easy definition and organization between accounts and their corresponding mail. There is also great improvement in the editing area, where you can add pictures into the message as well as touch it up. There are new stationary features and similar other functionality found in MS Word. Home run with this client, in this writers opinion.
-NOLA Tech
on Jan 27, 2010 | Computers & Internet
I accidentally change my browser,restriction is the message appear in my windows,how do i set this into my default?
As we all know, when the Mozilla Firefox is installed, another version called "Mozilla Firefox (Safe Mode)" is installed. But most firefox users don't know it's importance and would consider it to run in Safe Mode. This feature is also used to Change the Firefox settings/preferences.
If you've messed up with the security settings, add-ons, etc..etc.. we have to reset all the settings from the Mozilla Firefox (Safe Mode). To do this, follow the steps below:
For windows xp
Click "Start" then "Run" and type in "firefox -safe-mode" [Note: one space after "firefox"] and press enter. A new window will open up (shown below)
You can select whatever you want to restore, but if you only need to reset the changes you've made to the "Preferences", then simply select (check mark) the "Reset all user preferences to Firefox defaults" and click "Make Changes and Restart". Once you click the "Make Changes and Restart", firefox will restart.
If your operating system isn't Windows XP, then the commands are as follows:
Windows Vista and Windows 7
Click "Start" then "Start Search" and type in "firefox.exe -safe-mode" (one space after firefox.exe).
Mac OS
Open, "Application" and "Utilities" then "Terminal" and type in "/Applications/Firefox.app/Contents/MacOS/firefox -safe-mode" and press enter"
Linux
Open "Terminal" then type in "/path/to/firefox/firefox -safe-mode"
Good luck.
Thanks for using FixYa.
Sep 25, 2010 | Mozilla Firefox
Mail backup
MozBackup is a simple utility for creating backups of Mozilla Firefox, Mozilla Thunderbird, Mozilla Sunbird, Flock, SeaMonkey, Mozilla Suite, Spicebird, Songbird and Netscape profiles.
It allows you to backup and restore bookmarks, mail, contacts, history, extensions, passwords, cache etc. It's an easy way to do Firefox backup, Thunderbird backup ...
Apr 11, 2010 | Microsoft Windows Vista Ultimate Edition
I installed a addon for firefox and now firefox does not start again. it keeps saying windows:xbl error or somerthing like that. can u please tell me how to delete the file or reboot my notebook.
You need to go to C:\Users\<username>\AppData\Roaming\Mozilla\Firefox\Profiles\<profile name> (Windows Vista and Windows 7) and delete the addon, it usually has its own folder depending on the addon. For Windows 2000/XP, it would be C:\Documents and Settings\<username>\Application Data\Mozilla\Firefox\Profiles\<profile name>. If all else fails, delete the entire Mozilla folder from the Roaming folder (Windows Vista/Windows 7) or the Application Data folder (Windows 2000/Windows XP).
Mar 30, 2010 | ASUS Eee 4G Notebook
I need to install mail client to this computer
outlook express came as a default mail client on windows xp. windows live mail come on windows vista. in case you dont need any one of that. you cna use thunder bird or opera or microsoft office outlook.
be handy with your pop3 server address which your isp can provide you. and then you cna use any one of the mail client. just be handy with your pop3 incomming and outgoing server email address.
all the best
Oct 13, 2009 | Dell Dimension 3100 PC Desktop
Problems checking my e mail;
Hi!
You may try to refresh the page / send/receive messages, minimize and maximize the window if you use a client for your e-mail. If you use a browser for a web-based e-mail you can try to reduce the security settings (especially for IE) or just use another browser such as Mozilla Firefox e.g.
Hope this helps.
Apr 03, 2009 | Microsoft Windows Vista Home Premium with...
Default yahoo email
If you use Yahoo! Mail for all your email needs, some of the amenities of Windows seem to elude you. A click on an email link in your browser brings up Outlook Express or another desktop email program, not a new message in Yahoo! Mail. Trying to send a file directly from Word, OpenOffice.org or another office application yields the same, unsatisfactory result.
Fortunately, the state of dissatisfaction need not be permanent. It will be overcome by making Yahoo! Mail act as your default email program in Windows, which, if you use Windows 95 or later is an easy thing to do.
Make Yahoo! Mail Your Default Windows Email Program
To set up Yahoo! Mail as your default email client in Windows:
* Download and install Yahoo! Messenger.
* Select Tools | Internet Options... from the menu in Internet Explorer.
* Go to the Programs tab.
* Make sure Yahoo! Mail is selected under E-mail.
* Click OK.
Yahoo! as Default Email: Does Not Work under Windows Vista
Unfortunately, Yahoo! Mail as your default email program may be hard-wired to use Internet Explorer instead of your default browser, and it does not work in Windows Vista.
Make Yahoo! Mail the Default Email Composer in Mozilla Firefox
In Mozilla Firefox, you can turn to the Mailto 2 Webmail script for Greasemonkey to have Yahoo! Mail handle email links (even under Windows Vista).
http://email.about.com/od/yahoomailtips/qt/et_default_mail.htm
Oct 23, 2008 | Yahoo Mail
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
