Question about Motorola Mobility HS820 Consumer Headset
Pairing Motorola HS820 with Blackberry 8310
I can pair this headset with other mobile devices and occasionally with the blackberry - but more often than not it allows me to enter the passcode (0000) but then displays "waiting for Motorola HS820....". Blackberry say to disable the encryption but once the pairing starts, it is too late, and when I delete the device and start again it is re-encrypted
Whats the fail safe method to pair?
Thanks
    Genius:
  • 1,019 Answers
there is really no fail safe method to pairing a bluetooth device.
The main thing is recognition. i,d suggest trying to press the different buttons on the transmitting bluetooth device, whilst attempting to pair. i.e volume up/down or on/off et,c. to enable the device-blackberry to find and sync. i,d think the device that needs to be configured or setup correctly is the blackberry rather than the bluetooth device.
try changing the phone settings. to accept all incoming signals on bluetooth, or disable encryption.
hope this helps.
Mike @ Compurepair.
Posted on Oct 06, 2008
Motorola HS820 - cannot hear anything nor can others hear me
It turns out it was the Blackberry's problem, which could only be solved by a 're-boot' - take off the back of the Blackberry, pull out the battery for 10 seconds or so, and replace it. The BB will 'reset' and all was fine then.
Feb 16, 2010 | Motorola Mobility HS820 Consumer Headset
Blackberry Curve 8310 won't pair!
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 26, 2009 | Blueant Z9i Bluetooth Headset
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Problem with Blackberry Pearl 8100
    Did you try deleting all devices paired and then try pairing again?
    May 20, 2008 | Motorola Mobility H700 Wireless Headset
    Can't get the HS850 to pair with my blackberry
    Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
    Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
    H500 won't pair with Blackberry Curve
    It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
    Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
    Motorola Mobility HS820 Consumer Headset Logo
    523 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Lawrence Oravetz
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
