Question about Dell 924 All-in-One InkJet Printer
Just had cartridge refilled,printer says its still empty,and wont print. help!!
Just had the printer cartridge refilled but when re installed in printer the exclaimation mark flashes and it says the ink cartridge needs replacing. it will allow me to print an alignment page but thats it. please can you help as i have some important documents to print
  • colind Oct 06, 2008
    tried this but no chip found. there is ink coming out of it but it still wont register on printer and the computer still says black ink level low.
  • 661 Answers
Take it back to the refilling agent and report the error, I think some cartriges have a chip which needs to be reset.
Posted on Oct 06, 2008
Why lexmark 3550 won't print after installing new ink cartridges
Check your manual for instructions about this type of problem. Are you using the ink cartridges meant for your printer? Sometimes using refillable cartridges instead of the manufacturer's cartridges can cause the printer to still think the cartridges are empty, and display an 'on-screen' message that they need to be replaced, which could stop the printer from engaging. I have a Canon Pixma printer, installed refillable cartridges, and now the unit displays a 'cartridges are empty' message on PC screen; but the printer still works. The system just recently went into a non-printable mode displaying a more convincing message that the black cartridge is EMPTY, and completely stopped printing. The solution to this: press and hold the Stop/Reset button for about five seconds, and it overrode the issue and started printing. Moral of the story, maybe its best to just buy the manufacturer's printer cartridges.
Jul 26, 2014 | Lexmark Office Equipment & Supplies
Reset ink
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
This means you need to purchase and install genuine printer cartridges.
May 05, 2013 | HEWLETT-PACKARD Hewlett Packard Deskjet...
I refilled my ink cartrdge but my computer still thinks that it is empty and wont print
you need to restart the printer or check the printer menu software installed in your pc. look for installed old ink cartridge then try to print.
Feb 02, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Ml 1630 printer shows empty cartridge after refilling what is the problem
If your print cartridges have a plastic circuit on them, you are not able to refill yourself, it registers itself empty and it wont matter how often you refill it knows they were empty at some point. You have to buy new or refilled from a company. Try a printer that doesnt have the chips on the cartridges is what i ended up doing and brought a brother dcp500. Hope this helps you. Lisa
Jun 11, 2009 | Samsung ML-1640 Monochrome Laser Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Refilled Cartridges
I've refilled cartridges twice so far. The first time, the black was completely empty and the color was nearly empty. The printer accepted the color refill and not the black. The second time, I refilled both cartridges before they completely ran dry and both were accepted by the printer. The gauges don't register the ink, but it prints just fine. I just monitor the levels through the print quality. A friend with the same printer has told me that she only get 2 - 3 refills before the cartridge has to be reset, and that is a tricky process, but can be done.
Jul 26, 2008 | HP PSC 2355 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
Dell 924 All-in-One InkJet Printer Logo
541 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
