The thermostat kicks the heat on and off at will, regardless of the temp. Also, keeps resetting itself to 62 degrees, when we have it set to 68.
If you take the battery out for several minutes it will erase all the stored programs and when you put it back in, then you can manual select the temperature you want.
Testimonial: "We had tried taking out the batteries before, but probably not for long enough. This time we kept them out for about 5 minutes. The thermostat still kicks the heat off before reaching temp (and then it kicks back on again), but it isn't resetting itself to the wrong temp anymore. Thank you!"
