Question about Gateway Computers & Internet
I can't eject the optical drive to input dvd/cd, the eject button does not seem to be working? I also do not see the drive information on the START-COMPUTER window listing.
  • 320 Answers
Hi check the connection between your drive and motherboard also check power connector . Between connectors on the optic drive you need set up a jumper(s) on master or slave. if you can`t open drive in your OS there is a small hol on the front panel of the drive use needle or something similar to open it manualy
Posted on Oct 06, 2008
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
HP TOUCH SMART IQ500 DVD RW NOT EJECTING WITH BUTTON
1 - Power button2 - Slim slot optical drive with eject button3 - Hard drive activity indicator LED4 - Volume buttons5 - Mute button6 - 5-in-1 media card reader7 - 4-pin 1394 port
Mar 22, 2012 | HP Computers & Internet
Machine won't start - so put diagnostic cd in and now cannot eject it. Sift key eject does not work - is there any other way of ejecting cd from Dell XPS One
You may not be able to eject CDs or DVDs from your computer, either using the Windows Eject feature or by pressing the button on the drive. If the Recommended Solution above does not automatically return your drive to a working state, try these options:
  1. Attempt to Eject the CD in System Setup. Software may be interfering with the normal operation of the drive. Reboot the computer and tap the F1 key while at the Dell logo screen to enter System Setup. Then attempt to eject the CD tray using the button on the drive. If the drive ejects properly, there is a software conflict that needs to be resolved.
  2. Try a Diagnostic Startup. If the drive ejects normally in System Setup, try a Diagnostic Startup of Windows 7.
    1. In Windows, click Start, then in the Search box type msconfig and hit .
    2. Click Diagnostic Startup to load basic devices and services only.
    3. Reboot the computer and try to eject the drive when you get back into Windows 7.
    If the drive ejects correctly, look for burning software that may be controlling the drive and update it or uninstall it.
  3. Reseat the drive. The cabling of the drive may be loose, or the drive may not be seated correctly in the laptop. Refer to the Online User's Guide for your computer for information on reseating the cables or the drive in the computer.
  4. Update the optical drive firmware and the BIOS on the computer. In some instances the firmware of the drive may become corrupted or the BIOS may 'lose' the drive. Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
Dec 07, 2010 | Dell XPS One All-in-One TV Desktop with...
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Dvd drive is not reading and also ejecting out !
Hi
I would simply recommend replacing the drive as it sounds like the optical lens is shot in it.
Taz
Oct 30, 2009 | Dell (0F146) Internal DVD Drive
My cd drive will not open or operate
You might have a bad drive,have you tried removing the drive and re-inserting it? You can get replacement drives on ebay or you can also look at surpluscomputers.com they sometimes have them cheap.
Sep 26, 2009 | Dell Latitude D600 Notebook
Sony Vaio VGN-AW21M OPTICAL DRIVE PROBLEM
replace drive 35-50 bucks i reccomend a lite on
Aug 22, 2009 | Sony VAIO VGC-RA840G PC Desktop
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
CD/DVD burner tray won't open- unresponsive
the door may be stucked due to dust in door gears.
Nov 24, 2008 | Micro Advantage Computers & Internet
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Computers & Internet Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
