Question about Samsung T220HD LCD Monitor
Auto Adjust not working
The auto adjust button does not work with my Dell PC but it works with my husband's Dell PC. Is this something I can adjust or does the monitor need to be returned?
  • 1 more comment
  • Anonymous Apr 18, 2009
    I have the same problem, using DVI connection but my auto adjust just wont work. Using it with Win XP and XFX GTX 285
    Yea and im running it at max res, but some of the screen is out of the screen so have to scroll to see it.
  • IT aid
    IT aid May 11, 2010
    what type of connection are you use VGA or DVI?
The monitor is bad.
It's all over the internet... It seems to be a lot (of production line) issue... I am in BRAZIL and I bought one that's behaving the exact same way.
Dozens of forums in Portuguese (our language here, ICYDN) relate the same problem... Also checked English and German... STAY AWAY FROM THE T220.
Posted on Jan 16, 2009
Dell E193FPC montior that will display screen during auto adjust in progress. Screen then will go blank after it has adjusted. If you unplug it from the PC it will then back in, it will display during...
Are you using PCI EXPRESS Cards as your Display Card? if so Might be problem with Monitor itself which do not support few PCIx16 Cards. Check it out.
Aug 16, 2011 | Computers & Internet
How do I auto adjust my Dell S1909WX.
Please refer to this picture; the auto adjust button is the third button (from top) Dell S1909Wx Control Panel
Good luck. Thanks for using FixYa.
Jun 04, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Need to get screen size to show all . cant see
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Apr 23, 2010 | Dell E153FP 15" LCD Monitor
We have "auto adjust in progress" flashing on our screen all the time, How can we get rid of it ?
press the auto button for 5 seconds, if this doesn`t work , if you can enter the monitor`s menu and select factory settings.
Oct 27, 2009 | Dell Dimension 2400 PC Desktop
Dell moniter
there is a menu in Monitor. annd there is option that enable and disable auto adjust in Menu. check it out you will see.
Sep 06, 2009 | Dell Dimension 4550 PC Desktop
Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Jul 11, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Pop up auto adjust in prograss
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Jan 09, 2009 | Dell E173FP 17" LCD Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Samsung T220HD LCD Monitor Logo
386 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
