Question about Asrock 775VM800 Motherboard
My OS not running properly bcoz i configure the gstor utility system
What can do to rum my Operating System properly? i configure the gstor utility system,my computer did not work properly
Set it baack to defaults is all i can tewll you this board sux in my opinion wont even run when i install a brand new visontek x1550 256mb ram ddr2 graphix card it freezes at bios lil code in bios bottom ooleft corner 0078 no wer in manual says anything about any sort of trouble code however
3.06ghz celeron stock temmp 34 DEGREES FAREBHEIT
overclocked the fsb got it to 3,890 mhz or so and it still only run less then 120 degrees farenheit or 40-45 dgrees celsius using a stock coolermaster cpu fan very nice tho i think i could make it ppush 4.06ghz not gonna try it
Posted on Oct 14, 2008
Wher can i found the installer of my hp 3920 deskjet printer which is the operating system is vista
The driver for your HP product is already included in the Windows Vista operating system. You do not need to download a driver to use the product.
Check out this page to learn how to install the in-Operating System driver (in-OS driver) included in Windows Vista with your HP printer.
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing. Follow the on-screen instructions to run the utility. Download the Diagnostic Utility here: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-88700-1&lc=en&dlc=en&cc=us&os=2100&product=445442&sw_lang=
Mar 09, 2011 | Computers & Internet
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Feb 01, 2011 | Dell Latitude XT2 Tablet PC
Can the two operating system can be installed in same drive ?
Yes, you can have multiple OS's on the same hard drive, and partition. I've seen it and have done it before to my machines. You can choose at the boot menu which one you want (when installed), and can run Linux or XP, Vista, Mac OS... my personal favorite is a small OS called "SliTaz". It's a light, Linux-based OS that is very functionable to the user.
Mar 14, 2009 | Microsoft Windows XP Professional With...
After I launch messenger, use it, then close the application it will stall then I loose all internet connection. I have uninstalled and reinstalled Yahoo Messenger but the problems still there. What...
This problem is not bcoz of your messneger but bcoz of your operating system............. try installing the OS again & try it hope this will help
Dec 21, 2008 | Computers & Internet
Hot Keys
Follow this procedure to enable the special buttons or function keys on the computer or keyboard in the Microsoft® Windows® XP operating system.
IMPORTANT:
  • If software has been installed for use with a third-party keyboard or mouse, uninstall the software to ensure there are no conflicts.
  • On AMD™ or Transmeta™ processor-based computers, the function keys are hardware controlled and not controlled by a hot-key utility.
NOTES:
  • The volume button, brightness key, and disc eject button on some computers will not work if the HotKey Utility application is not running.
  • The Magnify button and the Fn keys will not function properly before the operating system has finished starting.
  • The setting may not be saved if the ESC key is used to close the Fn display. Press the ENTER key or allow the Fn display to close automatically to save the setting.
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type MSCONFIG .
  3. Press the ENTER key.
  4. In the System Configuration Utility window, click the Startup tab.
  5. On the Startup tab, under Startup Item , ensure that there is a check in the HKserv checkbox. NOTE: If HKserv is missing, reinstall the HotKey Utility application and the Sony Utilities Library.
  6. Click the OK button.
  7. In the System Configuration box, click the restart button.
Nov 13, 2008 | Sony VAIO VGN-S460 Notebook
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Booting problem of my PC.
i think u have not use bootable cd to reformat..
if u use bootable cd such problem will not occur.
once u format means u r system becomes new.. but i donnot know why such problem occurs..
it also depends on type of sevice pack u use
use service pack2 , it is stable.
if the problem is in harddisk .. consult u r customer sevice.
Jul 25, 2008 | Computers & Internet
I have a booting problem.
@headman333
try repairing your installation by reinstalling your OS
@jyothi143
try to run system restore in safe mode
restart your system...before windows logo appear press F8 continuously and select safemode..
click on START>All Programs>Accesories>System Tools>System Restore..
Choose a date that were you havent experience the problem like the day before...
Hope this helps...^_^
Jul 24, 2008 | Computers & Internet
Asrock 775VM800 Motherboard Logo
189 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
