Question about HP Office Equipment & Supplies
HP Photosmart D7100 Error code 0xc18a0506 removing ink cartrideges/powering dwon etc will not reset
5 Suggested Answers
SOURCE: Ink system failure, error code 0XC18A0506
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
SOURCE: remove an check cartridge problem in HP 2410xi printer
bought new
Posted on Apr 09, 2009
SOURCE: HP Photosmart 3310 all in way Error Ink System had Failed 0xc18a0101
I had this same exact problem. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Posted on Sep 08, 2009
pineworks
  • 4041 Answers
SOURCE: HP photosmart C5180 unk system failure with error
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: error 0xc18a0206 de hp d7100
Reset the product:
  5. Wait 60 seconds.
MY HP PHOTOSMART D7100 IS HAVING A PROBLEM ERR 0XC18A0001 IS IT FIXABLE?
The error means
PrintHead Failure / Ink system Failure
Hardware error
Try removing the printhead (If removable) and clean the contacts on it, if it doesn't works there are no ways to fix this error
ADCSFXworks Printing Center <3
Nov 29, 2014 | HP PhotoSmart Office Equipment & Supplies
Hp photosmart3210xi all-in-one Error 0xc18a0506
Hello Javier! Welcome to FixYa!
Error 0Xc18a0506 in usually a Ink System Failure error
You need to do some basic troubleshooting steps below and hope that it would fix the problem:-
  • Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  • Open the cover of the printer and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the printer and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify printer is functional.
  • Reconnect the USB cable, and try to print from the computer.
I hope this solution helps you and you have clear picture in your mind now
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 06, 2012 | HP Photosmart C6280 Printer
HP photosmart C5180 unk system failure with error code 0xc18a0506. Tried HP suggestion, off/remove cartridges/on - doesn't resolve it - Any ideas please?
Reset the product:
  5. Wait 60 seconds.
Jul 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc18a0206 de hp d7100
Reset the product:
  5. Wait 60 seconds.
Mar 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
OXC18a0205
Hi Try
Reset the product:
  5. Wait 60 seconds.
Feb 16, 2009 | HP - HP Photosmart 8250 printer
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
I NEED HP PHOTOSMARTD7100 CARTRIDGES BUT I DO NOT SEEM TO FIND THAT NO ANYWHERE
Here's a link that will sell to you
http://www.ink-refills-ink.com/printer/HP+PhotoSmart+D7100+Cartridges/15097/?src=gpsearch&gpprod=HP+PhotoSmart+D7100&gptype=cartridge
Nov 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
Jul 30, 2008 | HP Photosmart 8250 InkJet Printer
HI,
I do understand that fact that it did not work out for some other users , reason being the error which u are reffering to is related to the hardware of the printer . but it might work in some cases u may try the steps to reset the printer .
u can reset the printer to its factory deafults as well
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Thanks
May 21, 2008 | HP Photosmart 3210 Printer
326 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
