Question about GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Bottom Freezer Refrig
Fridge is not cooling but freezer is fine. When I shut off the temp control it clicks, when I turn it back on a motor starts running but it sounds like its chugging.
    President:
  • 1,462 Answers
I assume this is a frost free type with air drive from freezer to fridge to cool fridge.
if so, take back plate off inside freezer and you may find ice build up especially towards the top of the coils. melt off with a hairdryer carefully. the nother thing that may happen is that the return duct for air from the fridge may also become blocked with ice. this is more difficult as it is usually hidden behind the coils and the best bet in this case is to switch off for 24hrs with the door open
Posted on Oct 08, 2008
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Zanussi fridge compartment has stopped cooling but freezer is ok
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE PDS22SBRLSS Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
