Question about Intel DG31PR Motherboard
Password prompt removal
All the alterable options in bios like BOOT PRIORITY SELECT, DATE SETTING everything is not working.. They are being displayed in GREY color instead of BLUE. I've set user password. now i want to remove it, but it is not being possible. I've also tried removing the CMOS cell, but there is no improvement.. I like to have your treatment for the PC as early as possible because it is my friends computer.
    Genius:
  • 1,124 Answers
You have to take out the jumper that it is locking the bios on the motherboard (overwrite protection).
After that reset the system.
About the video check the monitor connections. If problem continues check the video card.
Posted on Oct 06, 2008
I can no longer access my bios through the supervisor password, therefore I can no longer activate boot priority. I need to repair a windows 10 continuous loop that resulted from an update gone wrong!
The password that was set is a security device and there is no back door. Options are; replace the BIOS chip with a known good programmed chip, replace the motherboard or remember the password.
Oct 01, 2016 | Computers & Internet
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Reset to factory default settings
which operating system ??
Shut down your computer and restart it.
Watch for the Compaq logo, then press the "F1" key to enter setup.
Press the right arrow within setup to go to the Boot menu.
Press the down arrow to access the "Boot Device Priority" option.
Change the first boot device to CD-ROM by pressing the down arrow until "CD-ROM" is displayed.
Eject the CD tray and place the recovery CD that came with your computer into the tray.
If you do not have a recovery CD, you can order one directly from Hewlett Packard.
Shut down and restart the computer.
The Presario will automatically boot from the CD and begin the recovery process.
Select the operating system your computer shipped with.
Many Compaq recovery CDs support multiple operating systems, so be sure to choose the operating system your computer shipped with.
Insert the operating system CD when prompted.
Enter the license key for the operating system when prompted.
The license key is typically found on a small tag located on the top or side of the computer.
or
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows-based PCs.
Be sure that you want to delete everything--this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer.
As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot". Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate.
If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Jun 25, 2013 | HP Compaq Presario SR2150NX PC Desktop
How to setup bios for booting form usb or sdcard
Step 1:
There are many good reasons for booting your computer from a USB drive. For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer. However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on. Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware. The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor. The POST only lasts a few seconds; therefore, press the "Delete" key quickly. Enter the administrative BIOS password if prompted to do so. Once you enter the correct password, you will see the main BIOS screen. Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key. Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option. Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option. Press the "F10" key to save changes and exit the BIOS setup program. When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive. Award or Phoenix BIOS Connect the USB drive to the computer. Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS. Enter the BIOS password if prompted to do so. Tap the right-arrow key until the cursor is over the "BOOT" menu option. Press the "Enter" key. Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list. Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility. After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
Feb 25, 2013 | ASUS Eee 4G Notebook
How to install new microsoft XP operating system
This worked for me:
http://www.buildeasypc.com/sw/windows_xp.htm
I have to ad, that if putting the cd in to your computer and restarting it doesn't give you an option to install the windows xp, you should go to bios by pressing "del" key on your keyboard just after you reboot and altering the boot priority from bios. (it's different in some computers, so i can't give you the details, but you can browse around for the boot device priority setting, and if you are afraid that you have changed something that you didn't want to you can always just reboot without saving)
May 03, 2011 | Microsoft Windows XP Professional
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
Windows xp will not boot on my hp mini 110.Keeps flashing to start up screen
Try selecting Last Known Good Configuration, or Safe Mode, and use System Restore option to go back to a date where the system booted correctly.
If neither of these options work, then you need to try to get into Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. If you are prompted to Boot from CD, you need to change your Boot menu Order in BIOS or Setup to boot from CD before it boots from Hard Disk.
  3. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  4. Type 1 to select C:\Windows
  5. When you are prompted, type the Administrator password. (usually blank, so just hit the Enter button on your keyboard.
  6. Type chkdsk /r (space between k and /) and press Enter.
  7. The process may seem to take a while and freeze at times, but it's working. Just allow it to finish on it's own. Once done, you can type exit, and press Enter. Remove the CD before the system starts up again.
Jan 15, 2010 | HP Pavilion 110-1030NR Notebook
Bios problem
remove your motherboard battery for some times and restart your computer. thanks
Jul 19, 2009 | Intel Motherboard
BIOS SETTINGS
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Feb 19, 2009 | Intel D845GLLY Motherboard
Does boot up
If you are getting the underscore in the upper left corner of the screen the laptop is not froze, however it cannot find an OS (Operating system- aka windows) This leaves us with 2 possible options:
1. Your system (Bios) has changed boot priority
  • Depending on your computer you may get a prompt to press a key to change the boot order, if this is the case make sure your C: drive is selected, or Hard disk drive as it is a laptop you should only have one.
  • If you do not get a prompt for a boot priority screen you will have to enter the BIOS or system setup, this is ussaly done by pressing "Delete" or "F2" when you first boot up you will see the screen and it will tell you what key to press. Go into the bios and look for the boot priority settings and make sure your hard drive is at the top of your list
2. Your computer's hard drive has been corrupted and you may have to reinstall the OS.
Jan 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Intel DG31PR Motherboard Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
