Question about Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827---PICTURE TURNS GREEN
Turn on tv works great. 1/2 hr of run time it turns green,Turn tv off for 10 min turn back on tv works great for 2-3 hours AT times. But most of the time it turns green with in a 1/2 hour to 2 hours.And there has been days where it worked just perfect allday long??-----It dosnt happen like clockwork it just happens whenever it feels like turning green .IT seems to happen a little more as time gos by. STRANGE ( (any pointers what it could be )) THANKS BUDWEISERBURTON
  • 4 more comments
  • judybill238 Nov 25, 2008
    I have the same problem. Picture turns green, faces may turn blue. It happen after about 30-35 minutes. Turn off, turn on may work again for 30-35 minutes. What the problem? does any one have fix?
  • djohnson75 Jan 10, 2009
    My 65inch DLP WD-65734 turns completly green after 20 or 30 min, the tech replaced the dlp chip & it didn't fix the problem, any other ideas ?
  • Anonymous Jan 21, 2009
    picture turns green and purple, and flickers, i was told by my tv repairman it was a bad optical block , which are expensive, is there a recall , as i was told if Sony's had this problem it had a recall and sony just replaced the whole tv as the optical block is very expensive,
  • TVAngel Apr 07, 2009
    Same problem here, Mitsubishi sent out repairmen they replaced some sort of circut board? The problem SEEMED solved yet several weeks later it started up again. Not only does it turn green now but also has green and red lines appearing then screen gets distorted with lines of color as screen sometimes turns almost black, colors run together and then it looks like it would if a signal was very weak or cable not connected. We turn tv off and after a few minutes, turn it back on and it's fine for awhile. Mitsubishi just came back today and said they need to WITNESS this. TV is fine at moment, they told me to record it and call back so they can see it. Repairmen are pointing to our Cable company blaming signal but not realistic. All other TV's fine, cable company has checked signal plus once they made first repair it worked for awhile then stopped working so it doesn't sound like a cable issue. Warrenty up in 17 days. I want this fixed. Any help appreciated. Will update after phoning Mits' again. Repairmen will contact me after advised by Mits' as to what action (if any) to take. thanks angel
  • MIKE BURTON Nov 18, 2009
    I JUST TOOK OFF THE BACK PANEL AND LEFT IT OFF .PROBLEM SOLVED!!!!TV HAS BEEN RUNNING FINE. STILL THIS TV IS A PIECE OF $H!T.AND THE WAY MITSUBISHI JUST SHINED ALL THE PEOPLE THAT BOUGHT THIS SET.THIS IS ALOT OF $$$$ WE ALL LOST AND MITSUBISHI DOSNT GIVE A sH!T.THEY KNOW THEY SCREWED UP ON THIS MODEL AND ITS LIKE THEY WANT US TO disappear LIKE IT NEVER HAPPENED. I WILL NEVER BUY MITSUBISHI AGINE.
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
alecoz@roadrunner.com
Posted on Jan 25, 2009
Testimonial: "YES IT IS A HEAT ISSUE(IF YOU HAVING GREEN SCREEN ISSUES LEAVE THE BACK COVER OFF AND PUT A SMALL FAN BLOWING IN THE LIGHTBULB AREA.PROBLEM SOLVED"
I started seeing the same issue on my tv, THinking it may be related to heat issues I removed the back cover where the lamp is housed and stuck a piece of folled up paper into the slot that that has the "cover open" switch. then put a regular fan to blow in there, this solved the issue . Now I need to check on the lamp fan when I have teh time to make sure its not out of service.
Posted on Jan 02, 2009
Testimonial: "YES THAT WORKS ,PUT A SMALL FAN BLOWING INTO THE LIGHTBULB AREA. THUMBS-UP (PROBLEM SOLVED)"
  • danshur Jun 19, 2009
    Yea I did the cleaning thing too, but the problem came back in about 2 months.
    I did the cleaning thing too but the problem came back after a couple of months.
Sony Wega Plasma 42XS955. Over 2 wks., gradually
I would check the capicitors on the power supply to see if the they are bulging at the top or leaking. I had a Samsung lcd that starting taking and hour to turn on then eventually it would not turn on. So I checked the power supply and saw four bulging capacitors that I replaced and now it's working like new.
Oct 31, 2013 | Sony Televison & Video
My 32TV has green light but won't turn on, or takes an hour
You may have failing power supply module, that will be the first place to look, look for caps with leaking/bulging top.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts: WWW.SHOPJIMMY.COM
Jun 12, 2010 | Televison & Video
Tv turns on then after about 1/2 hr to 2 hrs it will shut itself off and the on blinks red 6 times and I wont be able to turn it on until 10 min later .
ONe of the power supplies is overheating
This will need professional service done.
Check the web for Sony service near you
Jan 27, 2010 | Sony KDF-42WE655 Television
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
Tv turns off then on
It's time for a new lamp. What you are seeing is the result of a weak or old lamp and the TV sensing that it is drawing too much power and turning it off. I've seen this many times; a new lamp will cure. Be sure to buy an original Sony lamp as the aftermarket replacements are known to have problems. Please be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Mitsubishi WD-62827 62" Television Logo
2,069 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
