Error code IRC 3200 machine
Hi
Can i know what is the error code for this E000020-425
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
"E020" Black toner feed problem
Posted on Oct 06, 2008
How remove error code E00004-0002
canon copier IRC-3200 Error code E000004-0181
Apr 15, 2013 | Canon iR5880C
I have one irc cannon 3200 , work good but now ,he show me this error code E000733-0001 A NEED HULP , A HEVE ONLY THIS MACHINE IN MY OFICE , I WONNA KNOW WATS HAPEN , EN HOW CAN I FIX UP PLEASE , HELP ME
This error code indicates a communication problem between two electrical modules. The most common solution is to turn off the machine and then disconnect the flat cable that plugs into the back of the reader assembly (behind and below the document feeder), the connector has a button either side of it which both need to be squeezed to remove the connector. Check both ends of the cable and disconnect and reconnect it. Turn back on the power and if this was the comm error your problem will go away. If not, then try disconnecting all of the interconnecting cables between the machine and peripherals.
If none of the above works then you have an internal comms error and possibly a firmware error which will need to be upgraded by a technician.
Good Luck
Sep 25, 2009 | Canon IMAGERUNNER 2230 Copier
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Error code E00020-03a0
hello josephusjose,
E000-03a0-
this means that there problem with the CYAN drum /developer unit in case your machine is IRC 3200 series
Changing this unit will fix your problem
Jun 23, 2009 | Canon Office Equipment & Supplies
Canon irc 3200 error code E000584 - 002
We are getting in Canon IRC3220 E000020-460 and sometime
E000020-4a0 Codes.
Please advise
Thanks
Abdul
mearmi@hotmail.com
Jan 10, 2009 | Office Equipment & Supplies
E225, without a broken glass?
there is no such error code for a irc 3200 therefore turn the machine off unplug it froim the outlet and re plug then turn the machine on again that should take care of the problem
Jul 27, 2008 | Canon imageRUNNER C3200 Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
151 people viewed this question
jasbo
jasbo
