Question about Sharp AR-M550N Copier
Sharp copier m550n
I have a problem with the sharp photocopy AR-m550n it is blinking L4-03
  • 3 more comments
  • htekle27 Oct 06, 2008
    i have a problem with sharp photocopy AR M550n it is blinking L4-03
  • Anonymous Nov 10, 2008
    I also have the same problem it is on a AR-M620N model. Are they the same? But mine will have indicated ready to copy but then L4-03 will appear. I thought it is on the process section
  • Anonymous Feb 10, 2009
    I HAVE OPEN PROBLEM IN MY PHOTOCOPY I SHOW MESSAGE CALL SERVICE CODE L4-03 OK CAN YOU SOLVE
  • mamilema May 11, 2010
    error l4 02 in sharp ar5132
    Scholar:
  • 92 Answers
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Posted on Oct 06, 2008
My copier is telling to change cartridge and I already have filed the toner into the drum but the message is not going away. Please help
Posted on Jul 26, 2010
SOURCE:
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
We have a Sharp M550N copier. I know we can scan documents to email. Can we scan color documents from this machine?
It is a monochrome(black and white) copier. Generally, any monochrome machine only copies,scans, faxes, or prints in black and white only.
May 02, 2011 | Sharp AR-M550N Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
Sharp AR-M550N control panel 'locks up' intermittently
loose the panel and service it one or more othe switch is not active
May 20, 2010 | Sharp AR-M550N Copier
Is it possible to "lock out"trays 3 & 4 on a Sharp AR-M550N, so they can not be used by everyone? If so, How?
Yes, in user settings. Under paper tray settings. I don't know why you would.... But you can also change the paper size to a odd ball size too.
May 11, 2010 | Sharp AR-M550N Copier
Reducing on an AR-M550N
You can download a manual from http://www.sharpusa.com/~/media/813980603C1E4072A9071108E8971025.ashx?cop_man_ARM550_620_700.pdf
Jan 05, 2010 | Sharp AR-M550N Copier
The photocopier is making a loud clicking noise when turned on.
First thing I would check is the bearings on the upper and lower fuser rollers. When they dry out they will make a metallic clicking sound. Hard to tell what the sound is coming from without hearing it.
May 28, 2008 | Sharp AR-M550N Copier
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
Sharp AR-M550N Copier Logo
2,534 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
