Question about HP Pavilion dv9000z Notebook
HP Dv9800 Blank Display
My almost new (just 2 months old) HP Pavillion DV 9800 has developed an issue where display is completely blank after starting the computer. It flashes for a second and then goes off completely. There are no tones or beeps. I have taken out the battery and drained the power and then tried to turn it on but the issue still persists. A few days ago, there were few issues with Graphic card Nivdia but computer worked after restarting the computer.
Since the computer was purchased from eBay, HP says there is no warranty. I have tried using it with external display and it works fine.
Anyone have any idea?
  • 5 more comments
  • bloach Oct 06, 2008
    Please explain the solution fully rather than shooting randomly.
    There is no issue with wiring.
    I followed your solution. If I keep the escape button or F1 and F2 buttons pressed, nothing happens and I see the Windows boot sound after a while. If I start it and keep escape pressing up and down, there are strong beeps after a few seconds.
    HP won't provide warranty as I mentioned in the problem. Please read the problem before you answer it.
    I just tried to set up the external display and now external display is also not working.
  • bloach Oct 07, 2008
    I am returning the laptop to the seller for a refund. However, now external display doesn't work so I will need to take out the hard disk and copy the data to my computer. I have a hard disk enclosure so all I need to find out is how to take out the hard disk from my laptop. Can anyone please give me step by step directions for removing hard disk and copying data and I will select that solution.
    Thanks
    Thanks
  • HP Master
  • 19,396 Answers
Here you get Hard drive replacement instructions for HP DV9000 series.
Do not forget to evaluate and accept a solution when you are satisfied with the information given.
Regards
Posted on Oct 07, 2008
    Genius:
  • 3,422 Answers
  • HP Master
  • 1,879 Answers
It clear you got a faulty LCD display which is a common problem with laptops since the screen is always flipped up and down.
need to have it replaced at your own expense since manufacturers doesn't like ebay for some reason
about the external video output, let the computer to boot normally and use the Fn + Function key (check your keyboard) to activate
Posted on Oct 06, 2008
    Genius:
  • 1,011 Answers
Dear,
did u go for dust issue. did u tried to open that for any work. if yes, then did u check that, is there some dust inside especially with fans..
regards,
dont rate it until u satisfy with the solution!
  • SALMAN NASEER Oct 06, 2008
    did u do as i mentioned
    regards,
    Genius:
  • HP Master
  • 1,250 Answers
as you have said that there is a display on external monitor , this shows that your system is working fine, the problem is in the display panel, this is due to the cable that gives display to your panel, get it checked by a technician, you have to replace this cable.
  • 435 Answers
It seems there is some problem with your video adapter. Do you have an alternate one to try and use with this computer?
Let me know
  • Narmada Anand
    Narmada Anand Oct 06, 2008
    If your Video Adapter doesn't have any problem, then it must be some problem with the BIOS of your system. To resolve this
    issue, download and install an updated BIOS from the following methods:
    If you have HP Factory Image, then you can run:
    • HP Health Check
    • The online diagnostic HP Instant Support Professional Edition (ISPE).
    However, if your computer does not contain an HP factory image, you should:
    • Install the updates manually
  • Narmada Anand
    If your computer does not contain a HP factory image, you have to update the BIOS manually.
    Downloading and saving driver softpaqs to your computer
    You should download the driver softpaqs, save them on your computer, and then run the softpaqs to install the drivers.
    NOTE:
    When
    installing updated BIOS and drivers, you should always install the BIOS
    first and reboot your system before installing any other device drivers.
    1. Open a browser and go to the
      Software and Driver Downloads
      page.
    2. Choose one of the following methods of locating the correct drivers:
      • Click
        Start Detection
        under
        Automatically detect product names/numbers
        and follow the on-screen instructions.
      • Select
        Download Drivers and Software
        and enter the notebook part number from the Service Tag on the bottom of the notebook PC, and click
        to start the search.
      NOTE:
      If
      multiple notebook part numbers are displayed, verify your notebook's
      part number from the Service Tag on the bottom of the notebook PC.
    3. After selecting the correct notebook from the resulting list, click
      Software and driver downloads
    4. Click on your operating system from the list supplied.
    5. From the list of available softpaq downloads, scroll to the
      BIOS
      section, click
      Download
      for the latest version for the notebook, and then click
      Save
    6. Select a location, such your desktop, to save the BIOS.
    Installing the softpaqs
    To install the updated PC BIOS, perform the following:
    1. Double-click the PC BIOS softpaq on your desktop and follow the on-screen instructions.
    2. Reboot the computer following the installation.
  • 4,889 Answers
Well it is pretty clear that the problem is the display itself not the graphics card. A bad graphics card would give you no display on external monitor as well. As Ekse suggested it is probably just a bad connector. It can also be the LCD inverter board that is present inside the LCD screen of the monitor behind the panel. You can usually find an Inverter board for a pretty low price on e-bay. I bought one for 35$ the other day for fixing a client's Lappy. Worth a go if you are skilled enough in electronics. Otherwise the best thing would be to seek proffessional assistance.
Good Luck!
Sai.
  • eagle338
    eagle338 Oct 06, 2008
    Ok.. Thats not good.. Did you try flashing the graphics BIOS? Please provide us the model number of the graphics card so that I can guide you through the procedure. Also one more thing that can helpyou figure out what the problem is .. Just pump up the volume and start your system and see if you can hear the windows start up sounds and stuff
    Sergeant:
  • 208 Answers
A quick search on HP website shows that there atleast an offer of free repair for the exact problem you're having.~!!
http://h10025.www1.hp.com/ewfrf/wc/docum...
HP has identified a hardware issue with certain HP Pavilion dv6000, HP Pavilion dv9000 and Compaq Presario V6000 series notebook PCs.
If you own an HP Pavilion dv6000, HP Pavilion dv9000 or Compaq Presario V6000 series computer that meets the product criteria listed below and experiences one or more of the symptoms listed below, contact HP to determine whether you are eligible for a free repair.
NOTE: This service enhancement program is available in North America for 12 months after your original standard limited warranty expires.
Determine whether your computer is eligible for free repair
Identify the symptoms
If your computers model number and serial number are listed above and the notebook experiences one or more of the symptoms listed below, contact HP at 1-866-671-7362 during the Duration of the HP Limited Warranty Service Enhancement to determine whether you are eligible for a free repair.
The notebook has no power and no active LEDs.
The notebook does not start.
The battery charge indicator light does not turn on when the battery is installed and the AC adapter is connected.
The notebook issues a single beep during boot indicating no power.
There is no video on the computer LCD panel or external monitor.
The external monitor functions but there is no image on the notebook LCD panel.
Service enhancements and free shipping
Free shipping
If your notebook needs to be returned to HP for repair, the shipping costs are free. HP will immediately send you a postage paid container in which to send in your computer, and we will pay the return shipping.
Post-service warranty
After HP repairs your notebook, you will receive a 90-day warranty for this free repair only.
Service
After HP receive your notebook PC, HP will use its best efforts to repair and ship your notebook to you within 10 to 14 business days, depending on your region.
Contacting HP
To contact HP in North America call 1-866-671-7362 from 8:00am to 8:00pm MST, 7 days a week.
NOTE: This service enhancement program does not affect your current standard limited warranty. If you are experiencing issues or concerns other than those listed above, your current standard limited warranty applies.
I hope this helps~
GOOD LUCK~!!
  • 2,071 Answers
Just click below for troubleshooting guide;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00372748&dlc=en&product=3740781
Hope it may help you;
Regards,
VOTIT
  • HP Master
  • 13,433 Answers
Hey it sounds as the external is working fine that the internal lcd connectors may be loose or lcd board / inverter is faulty
  • Ekse Oct 06, 2008
    you will have to open up the laptop, check or reconnect the lcd cables / connecotrs (1-3)
  • Ekse Oct 06, 2008
    Check the cables, this can be easyer to fix than you think. A cable could be loose or broken.
  • HP Master
  • 6,487 Answers
Since the external display is working fine the problem here is with the laptop screen, that may got bad and already needs a replacemnet , because if the other parts are the one that is not working fine fine , if you use the externla display that shouldn't be working...
  • Mark Gil
    Mark Gil Oct 06, 2008
    The best thing that you can do to contiue using this laptop is tp have it take to a repair giy and let them checj the lcd monitor of this laptop and hopefully they can fix it the worse thing that can happen is to replace the monitor...
    President:
  • 1,952 Answers
Ur still warranty period then uget free service tecnician in ur pc
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Oct 06, 2008
    document.tlSearch.tx.value=unescape("")
    HP Notebook PCs - LCD Remains Blank or Displays an Error Code 83 When Resuming From Hibernation/Sleep Mode
    Understanding problems with notebook PC resuming from hibernation/sleep mode
    Run HP Health Check to download and install latest PC BIOS and graphic drivers automatically
    Run online diagnostics to download and install latest PC BIOS and graphic drivers automatically
    Download and install latest PC BIOS manually
    This document pertains to HP Notebook PCs with Windows Vista.
    The notebook PC may display error code 83
    or the notebook PC does not display anything on the LCD display after
    resuming from Hibernation/Sleep Mode or restarting the notebook. To
    resolve this issue, download and install an updated BIOS using one of
    the methods described below.
    If you have an HP factory image on your computer, you can run:
    • HP Health Check
    have u confident tat ur os is not corrupted...if its corrupted means reinstall ur os else reinstall ur bios setting by followin steps
    NOTE:
    When installing updated
    BIOS and drivers, you should always install the BIOS first and reboot
      page.
      • Click Start Detection
        under Automatically detect product names/numbers
      • Select Download Drivers and Software
      NOTE:
      If multiple notebook
      part numbers are displayed, verify your notebook's part number from the
    3. After selecting the correct notebook from the resulting list, click Software and driver downloads
    5. From the list of available softpaq downloads, scroll to the BIOS
      section, click Download
      for the latest version for the notebook, and then click Save
    mohammed marika thambi Oct 07, 2008
  • First, reformat the hard
    drive. Under Windows, you can format by going to My Computer,
    right-click the icon for the hard drive, and then select Format. When
    the format completes, you will have erased all files from the drive.
  • Since your computer now has an empty hard drive,
    you'll need to re-install the operating system with the original
    CDROMs. It's still possible, but pretty unlikely, that some shreds of
    your old files might still be visible. But finding them requires some
    pretty advanced sleuthing tools and a lot of determination.
    If that solution doesn't satisfy you, there are two other options you can try:
  • Hard Disk cleaning tools such as Disk Wipe, Drive
    Scrubber or R-Wipe & Clean claim to remove every last shred of your
    personal files. You can also search the Web for "disk wipe" or "file
    shredder" to find similar software options.
  • Remove the hard drive and hit it with a sledge hammer
    You will have to go through the 'Remove Disk' wizard,
    where WHS will try to move the existing files if there is space
    available. You could also switch off duplication prior to removal, to
    free up some extra space.
    When you re-add the drive, you could then re-enable Duplication, to allow the extra space to be utilised.
    a
      Genius:
    • 2,035 Answers
    You need to change the display screen of the laptop its defective....
      Scholar:
    • 116 Answers
    Have you checked all the wiring connections are they firmly connected.
    • 4 more comments
    • mastermind10 Oct 06, 2008
      To jump start it ---- press Esc button as soon as you turn it on, hold it until something happens can take 20 sec or more and may take more than 1 attempt.
      sometimes if Esc fails then restart and press F1 or F2 buttons then hold it. When it starts you follow the instructions it gives.
      I think its a problem with one of the following Ram, Rom, systemboard or Bios
      hope it helps, tell me if it does.......
      or try this if it still does not solve your problem
      remove the battery and take out the jumper, move it from slot 1+2 to 2+3 and back to 1+2. Put the battery back in, and the it Booted.mostly it starts working.
      I think you might have a failed screen inverter (FL inverter); this problem is very common with laptops. The inverter board acts as a power supply for the LCD screen backlight bulb, it converts low voltage DC power into high voltage AC. On most laptops the inverter board is located inside the display assembly below the LCD screen and you can get access to it if you remove the screen bezel (LCD mask). When the screen inverter goes bad the backlight will not turn on anymore or it turns on for a short time and then goes off, but you still can see a faint image on the screen and the external monitor works just fine. First of all I would make sure it’s not just a loose connection and reseat connectors on the inverter (it looks like you already done this part). Next, I would try replacing the inverter board. It might fix your problem with the backlight. It’s possible that you have a faulty cable, bad motherboard or even bad LCD screen, but I would try replacing the screen inverter first.
      Here is a simple diagram that will help you to understand how a notebook display assembly works and how an image appears on the screen. I’m not an artist and I tried my best drawing this diagram, so if you cannot see a laptop in this picture,
      for diagrams click this link below
      http://www.laptoprepair101.com/laptop/20...
      A generic display assembly includes a very few parts and knowing them will help you to understand witch part can cause a problem if you laptop video not working properly.
      Video cable. A video signal from the motherboard goes to the LCD screen through the video cable. The video cable connects to the motherboard (or video card) through the connector 1. The video cable connects to the LCD screen through the connector 2. The video cable (in most cases) is also responsible for supplying a necessary voltage for the FL inverter board. The video cable connects to the FL inverter board at the point 3.
      FL inverter board. This board is responsible for converting low voltage DC power (point 3) to high voltage AC (point 4), necessary to light up the backlight bulb. If the FL inverter board is bad, the LCD screen (backlight bulb) will not light up when you turn on the laptop, but you still should be able to see a very dim image on the screen.
      Looking for a new screen, video cable or inverter board? Find it here.
      CCFL (backlight bulb). When the backlight bulb lights up, you can see an images on the LCD screen. In most cases the backlight bulb is a part of the LCD screen and if it’s bad, the entire screen has to be replaced. By the way, some specialized repair shops can replace the backlight bulb itself.
      Lid close switch. The lid close switch is a small button that locates close to the display hinges. On some newer models there is no button, because the switch is magnetic. You can set up your laptop to go to a hibernation mode or to a standby mode when the LCD is closed. It’s done through power management software. These modes are triggered when the display is closed and the lid close switch is pressed down. If the LCD screen on your laptop will not light up when you open the display assembly, check the lid close switch is stuck inside (it might happen because the switch is dirty).
      the beep ensures that there might be problem in the RAM in *********** board please remove and reinsert the RAM . try cleaning the golden lines on the RAM with a rubber (which we use in schools for rubbing pencil marks ).
      and also check the link above which i had sended in my coment before that has a diagram of how the screen works that will give you more perfect idea.
      keep us updated for further queries.
    Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
    That is some sort of video failure. "Unable to initialize video (to display the post code)"
    Dec 31, 2013 | HP Pavilion dv2000t Notebook
    HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
    Most laptops have a "toggle":
    * output video only to internal LCD screen,
    * output video only to external HDMI port,
    * output video to both internal & external.
    Set the "toggle" to the best value.
    Jun 15, 2011 | HP Pavilion dv9000z Notebook
    Hplaserjet p3005dn blank display
    Is it blank and no back light?
    Either way the display might have went dead/bad. These printers are not that old. I would call HP support to have it repaired.
    Apr 19, 2010 | HP LaserJet P3005n Printer
    Blank Screen on start. No display
    You need to replace the motherboard. When nothing comes on the display this means the bios on the motherboard is bad and the board and cpu need replaced.
    Mar 17, 2010 | HP Pavilion dv2000t Notebook
    Like everyone else, my laptop is less than 2 years
    You need to address this situation to HP - chat with an agent concerning your problem ...
    start here ... http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&cc=us
    Oct 16, 2009 | HP Pavilion dv2000t Notebook
    Blank HP w1907
    If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
    If in warranty, they will send you a box by FedX second day and have repaired.
    This is a 19" monitor and will not be worth paying for repairs if not in warranty.
    Sep 03, 2009 | HP w1907 LCD Monitor
    Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
    hi,
    if nothing(even hp logo ) is not coming on the display then please try this.
    1.remove the battery and then press the power button for 30 sec.Again refix it and check.
    2.If windows sound is there then this mught be the issue with display.
    3.If there is no windows sound might be the issue with RAM so please get it checked.
    May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
    Both hinges of hp dv9000 broke now no displAY SEEN TOO
    HP has a recall on the Pavillion lappys
    if you call them and be persistent they will send you a box and all you have to do is send it in for a FREE FIX...
    My DV9310us has been back to HP 5 times
    Happy Fixing =)
    Apr 06, 2009 | HP Computers & Internet
    HP Pavilion dv9000z Notebook Logo
    506 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
