Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi 50603 no power.
Hello Big Irish.
i was hoping that you could help me with a problem.
here's what the tv is doing.
no power, no response from the front control panel.
there is no high voltage from the fly back.....
now, i looked at the middle PCB ( i am guessing the audio/video ) and there was some corrosion by the middle screw. the corrosion was an a cap, voltage regulator, and ,diodes. i cleaned off the corrosion and checked all of the surrounding components and they seem good but i still have no power.
also, i did look (just a visual pass) of the main board and i checked R529 off the fly back, it was not open. i also checked pin 4 of ic700 and had o volts (no ac). i didn't have 4.7 volts @ pins 3 and 4 of signal pcb's rf connector. Should ac have been on for this test?
this is where i am with the tv.
i hope that you can point me in the right direction.
i will check back and you can email me at bcssr at charter dot net
thanks
dave
  • 927 Answers
Good Day;
DAVE; Sorry about your problem. .....The TV's board has been damaged by the fluid, causing the PC to have poor/open trace connections. These boards are double trace, circuits top and bottom, so, you have many 'feeds'. You might be able to find some one in your area to repair them. New boards from factory are not available. Some places, factory , will rebuild these boards, it's not an easy fix.
Good Luck, big IRISH.
Posted on Oct 10, 2008
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Ws65809 tv
Good Day, TRAVLINMAN80;
Sorry for the late response but have been dealing with IKE down here in TX. I think the problem your TV is Fluid. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
TV NO POWER
Good Day, HOGBOYLE;
I would highly suspect that the TV's signal board has CRT Coolant (fluid) on it. Check closely and remove/clean with acetone. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi VS-50603 50" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi vs-50603 no remote.what is code
Good Day, ariley1604;
Please contact comcast, and look into U- VERSE.
Aug 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
MITSU VS - 50603
Good Day, wecalvin;
Suspect fluid on the PCB's.To find suspected liquid on the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Aug 05, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Damn TV....why doesn't it turn on when you push the power button??
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Apr 29, 2008 | Mitsubishi VS-50603 50" Rear Projection...
TV will not power on
Good Day, redraider;
It sounds like you need to call an Authorized Service Center. Have them come out and give you an estimate before repair begins. Your TV more than likely has fluid on the TV's boards, not easy fix.
Mar 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Won't turn on
Good Day, Check these two areas: 1. CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001. 2). CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB. Good Luck, big IRISH.
Nov 17, 2007 | Mitsubishi VS-50603 50" Rear Projection...
1998 mitsubishi big screen tv model vs-50603
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Dec 30, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
