Need to change my ip address - Computers & Internet
    Scholar:
  • 105 Answers
There will will be a network status icon in the system tray
Click on the icon bordered in red and a window will be opened showing the status of the connection.
Click on the properties button and a screen showing you the properties of the network connection will be opened.
Under the general tab, there will be an option called , Internet Protocol (TCP/IP). Click on it and select properties. Now u can enter the required IP address.
all the best
Posted on Oct 06, 2008
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
Hpow u change ip adres
Method 1:
Step 1
Step 2
Step 3
Step 4
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Sep 15, 2012 | Computers & Internet
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
