Washing Machines
Problem for Amana Washing Machines
Generic problem for all Amana Washing Machines
Extreme vibration of top loading
By JWB44 on Oct 06, 2008
extreme vibration of top loading amana washing machine model NFW7200TW
Comments:
Oct 06, 2008
- Already checked this, one of the mount bolds was not attached and the others were all loose. After I remounted and tightened the vibaration and walking actually worsened
Solution #1
posted on Oct 06, 2008
Not Rated)
Ekse
Rank: Guru
Rating: 88%, 4751 votes
the clothes may be out of balance, redistribute the clothes around the washer and try again,
Comments:
Oct 06, 2008
- It may also be a problem with the motor, would be best to have it looked at by a repair tech incase what I suggested doesn't work. Possibly the motor, its loose or something is not right in anycase.
Oct 06, 2008
- There's a couple brackets inside the machine near the top that help support and guide the actual drum that holds the clothes/water. If one of those brackets has come loose or broken off, it'd cause the drum to act weirdly. Also, the pulley wheel that the drive belt goes on, at the bottom of the drum, may have come loose if the drum can spin the wrong way. .... Read more at
http://www.bobvila.com/BBS/Washing_Machine_Extreme_Vibration-Appliances-1-T143.html
Solution #2
Not Rated)
kevin000
Rank: Wiz
Rating: 78%, 307 votes
check the bolts that connect the tumbler are tight.
you can check by opening the back cover.
Solution #3
Not Rated)
mastermind10
Rank: Guru
Rating: 86%, 45 votes
check out this link for proper help
www.applianceaid.com
Comments:
Oct 06, 2008
- for pictures and diagrams and instructions as what to do when.and how to do it your self click this link
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=52
Oct 06, 2008
- to stop the vibration
**Take the front cover off and you will find brake pad pieces in the bottom.
Now some say you have to pull the center out to replace the pads...I don't. Here's how I do it..
Remove old screws were brake pads use to be and loose them! Kits comes with new screws that you must use. The transmission will turn free without the brake pads. You will need a 3/8 stubby ratchet. Insert 0ne pad in place toward the front and line up holes with front set of holes in mounting plate. NOW....spin trans around until the pad is near the back set of mounting holes. I use an Allen key to align holes and put rear screws in. Once you get the back one in the 2 front ones are easy. Don't forget to bring a new belt with you!!!!!!!!!!!!
NOTE:.....You must coat the new brake pads with a little silicone grease
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
agitator does not move, I all ready replaced the coupler, but now agitator does not turn
Answer
I have a DAEWOO Front end loader DWD F1221 keeps coming up with a error code E8, can you please tell... (More)
Answer
I can't get the load to balance . The tub bounces all over the place .
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
