Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
50 inch tv
The screen and the glass needs to be replace. I know it comes out because my kids knock into it and we were able to fix it ourselves but now we need to replace itr-
  • 10,594 Answers
HI,
You can buy required parts for your Samsung TV HLN5065W from Parts Store.
Let me know if you need further info.
Thank you.
Posted on Oct 06, 2008
I have a Samsung ps51d450 plasma 51 inch tv and when I turn it on the screen is black on one side... Then it recedes line by line (especially if the programme has bright lighting)to leave one side with a...
Plasma tv's should never be tipped over on their side. It stresses connectors and the glass could break. You probably have to replace the entire screen panel. No it is not worth replacing it, due to the high expense. Next time, buy a LCD screen. You can tip them over with no problem at all.
Jun 09, 2014 | Televison & Video
We have a Model # 50GX49B 50" inch TV, That our
You need to set the antenna input back to ANT A (1), you are ANT B (2) right now that why you are not seeing any signals.
Use the INPUT button on the remote to scroll through until you see ANT A which is the one your kid use for the cable connection,
You should download this user manual:
http://www.retrevo.com/support/Hitachi-50GX49B-TVs-manual/id/371bh845/t/2/
Let me know if it works.
Dec 31, 2010 | Hitachi 50GX49B 50" Rear Projection...
I have a 50 inch avol flat screen. it has worked perfect for the year i have had it, last night put it on sleep timer and now the sound works but there is no picture, please help
I'm fixing a tv with this same problem. I think its the glass / flourecsent bulb, all my boards are good and clean no burn marks and no fuse issue. Also i checked all my capacitors, I all ready broke the glass trying to remove it so i don't recommend that but after i replace it , if it works i will let you know. but the bulb/glass is only thing that makes sense if everything has power and it hasn't been in a electric storm. and the bulb/glass is soldered with cables and that has to be where the light comes from.
Sep 07, 2010 | Televison & Video
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Televison & Video
Cat knocked over the Dynex dx-lcd32 TV and dented the screen in.
To answer your question, your probably better off buying a new television. LCD tv's are made of a thin layer of special ionic chemicals sandwiched between two plastic plates, this allows it to light up to produce an image. If your television image is distorted in any way, this means the ionic chemicals have leaked or become solidified, any repair (if even possible) would require replacing the majority of the television, and it will be cheaper just to get a new tv. Sorry Ron!
Mar 04, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Kids knocked tv over
Once the screen's broken, it's basically junk. The replacement screens cost AT LEAST as much as a new TV.
Dec 23, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Glass hit lcd tv
my LCD 50 inches that is scratches on the screen with a stick when my son swings the stick and scratches on the screen. Please tell me how to fix it.
Jul 06, 2008 | NEC MultiSync LCD15T Monitor
Panasonic th-50px60u
If the glass that you can feel on the front of the tv is cracked, then just replace the glass (called filter). The cost is about 150.00. If the pannel is cracked buy a new tv. It costs to much.
Nov 26, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
