Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate FreeAgent External 500GB HDD - Data Recovery
Accidentally plugged the laptop power into the external hdd, plug looks exactly alike but there is a difference in voltage input, now external hdd no longer powers up, any good suggestion on data recover please.
  • Anonymous Nov 12, 2008
    same issue; plugged a thinkpad adapter into my seagate drive by accident (all look same) and now it just blinks and won't even spin up
  • shabeeb May 06, 2013
    my 2.5"External HDD HXD3 320GB working but data is not reading so no need data.how can reapeare?i dond't wont to by new.
    Scholar:
  • 43 Answers
Well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Posted on Oct 06, 2008
Seagate drive beeping
Wait for it to be recognised and copy off your data before it crashes totally.
Jan 30, 2018 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 1 tb fell on the floor. when I connected it again it said 0 no partition found - what to do? I don't want to lose any data on it. thanks, Eli
If you are lucky and there is no scracthes on hdd disks, you can recover your files but not at home. Go to a recovery data office in your area and they can test your hdd and tell you what to do next. Do not try to recover data with any software because you can damage irrevesible your hdd and lose all your data.
Mar 13, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a seagate Freeagent Go 500gb and suddenly it is not recognized by my laptop.
Try with another PC, If still not recognising, then You have to open the Casing of your external drive. If you have any Warrenty remaining for this Drive, then let company people fix this. if no warrenty then Remove the HDD from the casing, Connect HDD to the PC with another External casing, and backup your Data. If no ditection with this method, then your HDD is Dead. Keep finger crossed best of luck
Feb 01, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I'm on Indonesia, exactly on Central Java... My HDD is Seagate FreeAgent 250 GB... I've plugged the USB cable and i connected the HDD to my PC... then, the led is just blinking for once, then black out,...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Aug 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I own a 320GB seagate freeagent hard disk and accidentally unplugged it from my laptop a few days back. It gives a beeping sound whenever I try plugging it into a laptop and I've tried 3 laptops, all gave...
Connect the 320GB HDD before switching ON the laptop and try to repair using scandisk option to repair the drive. Also use chkdsk /f option in command line mode.
Revert back for more assistance.
Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I havea seagate 500gb external hard disk, when i connect it wth the laptop the hard disk is not recognised on my laptop. i have windows xp professional installled in my laptop
Click on the link below and then click on the "Fixit" button. Windows has a patch for all external devices not recognized by PC's including HD's. This is especially an issue for those who've recently installed SP3. Best of luck with your problem.
Greg
http://support.microsoft.com/kb/925196
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
DATA RECOVERY
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jul 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Broken freeagent 500
This drive will need repairs to get the data. There is some good information on youtube on how to do a data recovery yourself or have a tech savy friend do it for you.If you want a service to do it for you, there are plenty: Data Recovery NYC. Also there is good information on hdd repairs on hddguru.com.
Jun 21, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,076 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
