Question about Microsoft LifeCam VX-3000 Web Camera
Sound the lifecam works fine but whenever i call my sis there is a horrible buzzing sound. I'm guessing there is some type of interference but weve tried everything can you help? We know its coming from her cause it only does it on our chats?
Stop buying microsoft ****, you can buy from any other company and get the help and support you need and most will refund the product if returned within so many days.
Posted on Oct 11, 2008
Samsung makes buzzing noise, gets louder when volume is higher
you may be hearing a buzz from inside the set---it is not rare for a transformer or other part to vibrate hard enough to produce this kind of sound.
Another common cause is the surface the set is sitting on===if hard and not fully supporting the set evenly this can cause this problem also.
On a set like the one listed here it is likely coming from the power supply but can be from other areas as well.
May 25, 2012 | Televison & Video
Whenever I use one of the cleaner amp models i get an aggravating buzz. The buzz only occurs when I play and is not constant. (The buzz is not there when I'm not playing). At first I thought my strings...
Try moving your guitar around and oriented differently as it MAY be picking up magnetic fields from equipment in the area. Some pickups really are sentive to interference.
The effects for modeling MAY have a noise gate that requires a certain signal level before unmuting which would explain why you have to be playing to open the gate and hear noise that is really there all teh time but muted.
Dec 27, 2010 | Line 6 POD HD500 Amp Modeler and Multi...
Buzzing in audio
It sounds like there is power interference on the audio wire. To be sure try plugging in a headset mic and see if audio noise goes away. That will isolate it to your webcam, and if the wire in it has interference you'll probably have to get a new one as the cost of repair would exceed the cost of a new webcam. You can try the free webcam test tool to try different mic combinations and see how the audio sounds.
May 09, 2010 | Microsoft LifeCam VX-6000 (68C-00001)...
Sound problems when recording video with LifeCam VX-1000
plug pc direct into wall check the grounding of the pc make sure sound card is not loose.
Jul 04, 2009 | Microsoft LifeCam VX-1000 Personal Web...
Interferance with sound
Normal 0 If the people you are talking to have speakers they hear you and you will get feed back of your voice. Have them turn down the speaker level or better yet use a headset and this will no longer be a problem.
Hope this helps. Bud
Mar 18, 2009 | Microsoft LifeCam VX-1000 Webcam
Mbox2 mini digidesign buzzing
Are you running passive speakers if so try using a ground loop isolator this should stop any noise interferance.
Jan 22, 2009 | Digidesign Mbox External Sound System
Microsoft webcam VX 6000. Buzz on video capture
I took the cam apart, removed the mic from its seat and gently separated the red and black wires - ran the red one over top the lens and the black one underneath. Replaced the mic, screwed it all back together and the problem is gone. For now. One tip is to record sound using Windows Sound Recorder while you're doing this, watch the input line and when it goes flat you know the buzz is gone. While it buzzez, the line will be active.
Apr 02, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Apr 24, 2007 | InFocus ScreenPlay 4805 Multimedia...
Microsoft LifeCam VX-3000 Web Camera Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
