Question about Toshiba D-VR4 DVD Recorder/VCR
Error Message C203 on Toshiba D-VR4SU DVD/VCR Combo Recorder
I have tried 3 different brands of DVD, all DVD-RW as specified and I cannot record from the TV on any of them. According to the manual, this error means "cannot record - no disc space." This cannot be correct as they are brand new dvds with nothing recorded on them.
Any help would be appreciated.
Thanks
SOURCE: Error Message
The manual says to press the display button (just below the eject button) on the remote. This worked for me.
Posted on Nov 12, 2006
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: Problem with DVD-RW's
I had a very similar problem with my Toshiba D-R2. I found two firmware updates on the Toshiba website. One was called 1314.iso and the other was called 1416.iso. All the instructions are there for how to burn a CD and install it on your DVD recorder. It solved my problems - hope it works for you.
Posted on Dec 12, 2007
  • 3 Answers
SOURCE: Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
Posted on Apr 08, 2008
  • 2326 Answers
SOURCE: I NEED A MANUAL FOR A DAEWOO DF4150p dvd recorder/ vcr combo please help
Click here to get the user guide for your device.
Posted on May 16, 2008
DVR90VE DVD Recorder / VCR Combo: error E 4 54037380; will not format...nor load dvd...
It seems like this device only supports DVD-RW 1x-2x try using these speed ratings!
Good luck Bruce
May 05, 2010 | Sylvania DVR90VE DVD Recorder/VCR
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot record on DVD-RW disc
Somtimes if you change brands of dvds will help!
Dec 13, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Open Questions:
See all Toshiba D-VR4 DVD Recorder/VCR Questions
Toshiba D-VR4 DVD Recorder/VCR Logo
353 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
