Question about Jwin JX-M20 AM/FM Radio
JX-M20 tuning and volume
I just bought a JX-M21. When unlocked, the volume and tuning buttons won't slide. I can't select frequency or volume.
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
How to tune my thomson tv? got a universal control with it can t find a way, please help, thx loads
if you want a manual fine tuned just go to set up menu then select preset and and then select manual fine tuned. select desired channel to tuned and then you can use the volume up/down button to manual search and tuned to the right frequency of the channel.
Oct 04, 2012 | Thomson 29DM400 29" TV
Dear expert, i have some problem with my tmobile htc hd2, i bought from ebay & it was unlocked until few weeks ago it worked normally. but one day the problem happened, i can't acces my...
First off please access your sd card via computer and make some space on the card . Its always ideal you keep 20 % space free on the card .
Now please do a hard reset of the phone ( considering that you are on default windows mobile 6.5 )
Go to
  1. Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
OR
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
NOTE : PLEASE TAKE A BACKUP OF YOUR DATA , USE PIM BACKUP,
Aug 03, 2011 | HTC HD2 Smartphone
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I bought an iWave FM transmitter and it says to select the frequency 87.5 on my radio but I could not find this radio station it starts with 87.7 and could not make it play my mp3....how can I solve this?
There is no 87.5 on your radio so that frequency won't work -- you have to pick another frequency. Find an open frequency on the radio you want to transmit to. Then use the up/down buttons on the right to tune the iWave to the same frequency. That should do it. If you want to save that frequency on your iWave you press and hold the round button at the center bottom of the unit. The left/right arrow button on either side of the round button can be used to click through your saved frequencies. It's not very complicated, but it baffles me that they include no instructions whatsoever with this unit. Otherwise, it works pretty well.
Dec 12, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
Dec 12, 2009 | OEM Systems Car Audio & Video
No Sound
Have you tried checking if the volume control is locked?
To unlock it, you have to press the < > and the menu button simultaneously to unlock it.
Aug 04, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Cu Ft for Sub
EN-SW100 EN-SW120 EN-SW150
PORTED
Volume (litres) 28.5 48.28 91.28
Volume (cuft) 1.008 1.705 3.223
Port diameter 76.2mm / 3" 76.2mm / 3" 101.6mm / 4"
Port length 255mm / 10" 225.3mm / 8-9/10" 242.5mm / 9-1/2"
Tuned frequency (Hz) 41.6 33.0 34.2 SEALED
Volume (litres) 15.71 28.58 85.53
Volume (cuft) 0.56 1.009 3.02
Tuned frequency (Hz) 69.9 53.9 44.4
If this doesnt come out right, look at the following link...
http://www.fusioncaraudio.com/north-and-south-america/suggested+encounter+subwoofer+enclosures+sizes-12-technical-support-detail.aspx
Jan 08, 2009 | Fusion 10" Single-Voice-Coil 4-Ohm Marine...
Locked keys
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
May 18, 2007 | Jwin JX-M20 AM/FM Radio
Jwin JX-M20 AM/FM Radio Logo
51 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
