Question about Toshiba 57HX83 57" Rear Projection HDTV-Ready Television
TOSHIBA 57HX83 NO VIDEO SIGNAL BUT WITH AUDIO - EVERYTHING WITH MENU DISPLAYS - BUT NOT THE VIDEO SIGNALS. I TRIED ALL THE INPUTS BUT STILL THE SAME. PLEASE HELP.
  • 3 more comments
  • akuning Oct 19, 2008
    ALL THE CABLES I AM USING ARE 100% GOOD - TESTED FROM A TV BESIDE MY PROBLEM ONE.
    I GET NO VIDEO BUT WITH AUDIO - MENU DISPLAYS ALL OPTIONS AND DOES THE MAGIC FOCUS. WHAT COULD BE THE PROBLEM?
    THANKS
    TOSHIBA 57HX83 - DID RESET AND CHECKED ALL CABLES I AM USING AND STILL NO VIDEO BUT AUDIO ONLY - MENU DISPLAYS ALL OPTIONS BUT NOT THE VIDEO SIGNAL.
    THANKS
    AKUNING
    ATTN: electech1
    I WOULD LIKE TO MAKE SURE THAT WE ARE ON THE SAME MAKE AND MODEL.
    TOSHIBA 57HX83.
    I WOULD LIKE TO KNOW ABOUT THE THE LOCATION NUMBER FOR THAT TRANSISTOR IF YOU MAY. I'LL ALSO CHECK THE CERAMIC CAP.
    THANKS.
  • akuning Oct 23, 2008
    the problem is still the same - NO VIDEO BUT WITH AUDIO - MENU DISPLAYS EVERTHING ON SCREEN - ABLE TO DO MAGIC FOCUS - PLEASE HELP
    Sergeant:
  • 306 Answers
How is it connected - what cables do you use? If it is HDMI try unplugging it and plug it back in. Sometimes this will reset the picture. If it's not HDMI then you will need another setting.
Posted on Oct 23, 2008
  • AbdulRahiman S Oct 23, 2008
    You have a problem in the deflection circuits. either hozontal or verticle.
    else try this..
    Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues
    Brigadier General:
  • 6,966 Answers
Based on your post/description, it would appear that the internal switching/logic of the unit is faulty. It does not switch/select from one video source to another. This is ganged but separate from the audio electronic selector. In most Toshiba models, this would be the A/V board.
Your options offhand are then rather limnited, open the unit for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 19, 2008
    Sergeant:
    Champion:
  • 258 Answers
Check the mode of your tv set if its set to tv or cat it could be in audio mode only check your remot control and try changing it to tv or cat mode
  • 905 Answers
This is some components failing , sometimes leaving the tv unplugged for a while will bring it back for a little while but will go into failing mode again.
the only way to fix this correctly is to replace the bad components or if you still have a warranty use it. otherwise you will have to call a tech.
for the problem of the video it seems one of the problems causing no video or NO PIC is, C511 10NF CERAMIC, or a TRANSISTOR SW
if you would like more info , please let me know
  • 6 more comments
  • jason Oct 19, 2008
    the first thing to do would to be , to make sure all solder on the board that don't look good be resoldered , do all the stuff that gets hot first including the flyback transformer
    i'll be back with some more procedures to make sure we get everything covered before we start taking out stuff , also look for bulging caps or leaky ones or when tested they will be an open
    talk to you in a bit
    sorry meant to get this in , the chip ( eeprom ) that switches the video input source should be checked for bad solder , the ceramic discaps any electrolitic caps and the transistors around the eeprom chip
  • jason Oct 20, 2008
    I only have some info on that TV
    I can't pay $30 right now to get the service manual
    but I will help you with what I know
    can you upload a pic?
    fact: I have been getting alot of failing discaps lately , just had one in my craftsman drill charger..
    also in the advent tv and all these items that I've encountered have been fairly new items , but some of these electrolitic are drying up , so they don't bulg all the time , they just dry up and become an open (on the DMM diode check).
    I'll be honest its not always that easy to find the problems , I say problems because if something went , it was because another or two has a low value or is done, and checking some of the components in the board is impossible, because you will just read other components values.
    resistors can be read most of the time , transistors can be most of the time and pr's , but it depends on the circut and how it is connected
    be back with more when you let me know what you get after you resolder any solder that don't look shiny or good , also check for brown areas on the board , which could indicate a problem
    electech
    quick check : -24v and +24v at the STK conversion chip , to find out what your chip setup is, type it in here and it will give you results for the nte equavalent (PDF file)
    click here :
    http://nte01.nteinc.com/nte/NTExRefSemiP...$$Search?OpenForm
  • jason Oct 23, 2008
    check the tuner fo resoldering as this can also cause the video circut not to function properly
    I'm also doin some research on this problem
    so i'll be back in a bit with more stuff to check
    electech
    whats the chassi # ?
    have you check the resistors on the stk's be cause if that totally failed then it will not drive any video input to the chips , the menu is driven by one of the stk's , so one of them is surely ok , but the 22 pin one should be checked , the other is an 18 pin connection
    can you find the chassi # on the main board?
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
good luck...
    Genius:
  • 1,447 Answers
HI-
on the remote, is there a button that will let you change the option or set it to video? Try unplugging the cable as well and try different ports from the back till you get the video. you will have to video source cable and plug it to other available ones. try using a different cable as well if you have spare.
Hope this helps
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Oct 19, 2008
    HI-
    Could be the A/V switch on the board itself, or some wiring, and a port problem. better have it check from a servicer.
    Thanks for using fixya!
How do I connect DVD player to tv with yellow,white and red cables?
Yellow is the composite video signal , White and Red is the Audio stereo signal.
You will need leads that can connect to the DVD player for these signals and connect them to the video and audio inputs of the TV .
If your TV doesn't have video and audio inputs, you will need a modulator box to combine these signals and send them to the areal input.
Jul 14, 2016 | Televison & Video
Inopeative tv
is the signal input board faulty? can you receave any signal from any source?
Is everything connected correctly?
Jul 21, 2008 | Televison & Video
Sony STR-DG710
try to reset the tv throught the menu options, if that fails then the video inputs or video components in the tv needs repaired, if you have a "S Video" input you could use that or have the TV repaired.
Nov 14, 2007 | Audio Players & Recorders
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Apr 12, 2015 | Toshiba REGZA 47HL167 TV
I have a Toshiba model number 50A62. The menu comes up but no picture displays when trying to view a channel or movie.
Typically when your menu appears but you are not receiving other input signals, it means that your connections and/or inputs aren't correct. Double check all of your connections from the source (cable box, VCR, DVD, etc) to the TV. These connections should always be color coded and run from OUT (source) to IN (TV). Depending on the connection you are making you may have to change the input channel as well. There should be a button on your remote labeled Input or Video Source. Use this button to cycle through your available inputs. Once you've checked your connections run through the inputs and see if you get audio/video on any one of them. If you do, make note of it, so we can further troubleshoot your issue.
Jul 18, 2011 | Televison & Video
How do I connect my Toshiba LCD television to my computer using hdmi
HDMI carries both "audio" and "video" signals, while DVI carries only "video" signals.
Does your computer have a HDMI-output port, or separate DVI-video and stereo-audio ports?
If the former, then one HMDI-to-HDMI cable will make all the necessary conections.
If the latter, you'll need a cable to connect "line-out" from your computer's sound-card to the left/right RCA-jacks stereo-inputs, and you'll need a DVI-to-DVI cable to transmit the "video" signals.
Oct 22, 2010 | Toshiba Computers & Internet
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Video input problems
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
May 27, 2006 | Toshiba 46HM95 46" HDTV
Toshiba 57HX83 57" Rear Projection HDTV-Ready Television Logo
172 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
