Question about Sony VAIO VGN-A150 Notebook
SONY VAIO BATTERY CHARGING
I have a Sony Vaio BZ11MN and my battery always stop chrging at 80% giving a massege saying pluged in not charging. what can i do
  • Anonymous Mar 13, 2014
    my sony vaio laptop not charging above 80%
  • 3 Answers
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
Posted on Feb 09, 2009
Ginko doesnt know what he is talking about... Firephox nailed it.. it is a setting the vaio control panel... i would recommend keeping it on.. it helps battery life.... but if you want a full charge for a road trip... turn it off.. charge and weeeeeeeeeeeeeeeee %100 battery life.
Posted on Apr 21, 2009
  • Sony Master
  • 19,396 Answers
You need to replace a battery, go to a computer shop that have replacement batteries with your laptop, and ask them to have a quick look, if battery stops at 80%, it should be replaced.
Note: if battery is still functional you can use the computer in this state, 80% charge is still enough to power your laptop for a good time.
Posted on Oct 06, 2008
Sony vaio battery went dead n now won't startup normally
Does your battery not start the computer up at all or it starts the computer up but something is wrong with the battery
Example the battery only charges to 80% then stops chargeing?
battery just can hold a charge at all etc.
Mar 17, 2013 | Computers & Internet
Battery in my VAIO not recognized
The battery may be dead. How old is it? A battery has a "lifecycle" of sorts, just so many charge/discharge cycles.
Dec 27, 2012 | Sony VAIO Notebook
My "sony vaio vgn txn15p"
if your Sony is older then 3 yrs I urge you to get a new battery. Make it last longer by draining the battery and charging it up everyday. This gives it a work out and helps it not get lazy.
May 02, 2011 | Sony VAIO VGN-TXN15P/W Notebook
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
1. http://www.ghacks.net/2008/02/02/sorry-you-cannot-use-that-battery-because-it-is-not-made-by-us/
2. http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
3. http://sarabannerman.blogspot.com/2007/04/sony-laptop-battery-mal-ware.html
Oct 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
I get the message ''Battery Low'' if I have connected the SONY VAIO to a ower supply
If you connect a Sony Vaio to a power supply, and the screen says 'Battery Low' on the lower right hand corner, and it does not go away over several hours of charging, then it could be a bad battery that needs to be replaced.
Jul 11, 2010 | Battery Technology for Sony Vaio FXA...
I just want to know how to use battery of my laptop sony fz410e in order to long live. addition i just want to know what is damage to my laptop weather battery software or harward? if every one know the...
Most Sony Vaio have a utility installed in power management called Battery Care Functions.
You can check in Start/Control Panel/Vaio Control Panel
Expand Power Options and on the right hand side you should see a box with Battery Care Function tick box.Select it if not selected already.
Sony recommends that if you are not using the battery, you select this function to prevent the battery from charging to 100% as this may decrease the battery life.
The best is 80% or 50% and charge it fully only if you are going to use it.
Regards,
Purito
Oct 18, 2009 | Sony VAIO VGN-FZ410E/B Notebook
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
fix first the power adapter/ it not charging some problem of your power adpater,, check the charger if it is working properly or not, then follow by dc connector should know that your dc connector has no deffect// if its okay check the motherbaord of your pc maybe som chips need to replace or damage...ic capacitor fause..ech..
Sep 10, 2009 | Sony VAIO PCG-K23 Notebook
Laptop Charge troubleshoot
This can be due to a dead cell in the battery pack,Could also be the charger is going bad or shutting off prematurely.
Please rate this a fixya
Feb 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony Vaio Laptop Battery - increase charge
Hi Sony battery,
did you mean to say that you battery only remain at 50% and never exceed this amont ??
Normally all the notebook if you keep charging it should come up to 100%, but only a few case that will face the problem
1.problem with battery itself.
2.problem with ac adapter (I face very much problem here not continues power suplly)
3.problem with motherboard the module that deal with charging battery.
Goodluck,takecare.
May 08, 2008 | Sony VAIO PCG-K35 Notebook
Sony VAIO VGN-A150 Notebook Logo
906 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
