Question about ViewSonic VA1912wb 19" LCD Monitor
Monitor did not work..
Whwn I turn on the power,the monitor shows 'no signal,Analog'..then green light becomes yellow.
  • 2,071 Answers
Just click below for more information;
http://www.geekswhoknow.com/articles/reasons_you_get_a_blank_screen.htm
Hope this may help;
Regards,
VOTIT
Posted on Oct 06, 2008
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Turn monitor on and the light stays yellow will not turn green and screen stays black
When it lights up the yellow light instead of the green one, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | Computers & Internet
AS SOON AS YOU TURN ON THE MONITOR IT SHOWS NO SIGNAL ON THE SCREEN. SO THERE IS SOME POWER TO THE SCREEN OR YOU WOULD GET NO SIGN OF LIFE AT ALL AND THEN IT SHUTS THE SCREEN OFF YET THE POWER LIGHT SHOWS...
Hi! If this is the case, the problem will surely be on the monitor cable going to the pc. If the cable is loose or faulty it will give you a no signal message. YOu will need to secure the cable of the monitor for it to work. Hope this helps and thank you for using FixYa!
Aug 28, 2010 | ViewSonic VE155b 15" LCD Monitor
Monitor power light flashes yellow/green
the monitor power light turns green and then switches back to yellow but there is no signal.
Nov 28, 2009 | Acer AL1917W LCD Monitor
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
ViewSonic VA1912wb 19" LCD Monitor Logo
98 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
