Computer chip i like to make my computer faster
  • 6,487 Answers
If you want to make your computer faster this are the possible things that you can do;
Remove unnecessary program and the best one is to add up some or increase the RAM or memory of your computer that will definitely speed it up..
Hope that helps...........
Posted on Oct 06, 2008
Computer will not boot up only beeps
how many beeps fast or slow i ask because all bios types have set answers ie :
phenox bios 3 beeps = faulty ram chips
the faster you reply the faster ill have an answer for you!
Jan 28, 2014 | Acer Computers & Internet
Speed up computer
you can but a daster cpu but you might need other equopment to keep the machine cool. Generally, if you buy a faster chip you will need better cooling.
A solid state drive will speed your machine up, SSDs are expensive but very quick, much faster than a magnetic hard disk. The best , most reliable bang for buck SSD is the SANDISK EXTREME PRO at the moment, these come with a 10 year warranty.
You can add faster ram . Lower CAS latency and faster chips really help.
Jan 11, 2014 | Intel Computers & Internet
Wanting to upgrade 32 bit CPU to a faster 64 bit model
typically not. 99.9% of the time manufacturers will put the 64 bit chip into the computer if it can support it and if not the 32 bit. If your system is running a 32 bit chip now, you will have to stick to that chip unfortunately.
Aug 05, 2013 | HP Pavilion dv8330us (882780647763) PC...
How do I change ram speed to from 533 to 667 to enable new faster memory?
Before changing to faster RAM, you must first make sure your computer can handle the faster. Motherboard manufacturers, particularly the ones supplying motherboards for consumer desktops/laptops restrict the speed and total amount of RAM those computers can have installed.
To verify what limits your desktop has, the easiest way is to visit the website below and have it check your system.
It will list what you currently have installed and what your maximum upgradability is.
1. Check the box to accept the terms of service and click on "Download The Scanner". 2. After the download, double-click the program to run the scan. 3. After the scan is complete, it will open a browser window to display what memory is currently installed, the size, speed and of course, what is the limit your system can hold.
In the event that your system is not capable of running RAM that has been certified to run at higher speeds, it is not advisable to install the higher speed RAM as your desktop/laptop will not run at the higher, but rather the system will "underclock" (run at the slower speed) itself in order to utilize the RAM and maintain stability.
Aug 10, 2010 | Dell OptiPlex GX520 PC Desktop
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
Difference between celleron and pentium which is better to use
Celeron has always been known as the cheap mans 'chip' because it is less expensive. Celeron tends to overheat quicker and doesn't cope as well with high demand. In saying that a Celeron does it's job - just don't expect miracles. Pentium is the quality 'chip'. Works well on high demand computers, faster at responding and less likely to have problems.
Jun 13, 2009 | Intel Computers & Internet
Can I install DDR3 RAM chips on my laptop?
Sorry to say but that is not possible upgrading the RAM using a different RAM chip will not work, since your MOBO only supports DDR2 of RAM but if you just want to make the computer work faster you go and upgrade the DDR2 RAM up to 4GIG....
May 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Transferring pictures from Computer to the camera
This is best done using a USB card reader.
You just drag & drop or copy & paste files, just like you would do moving files from folder to folder on a hard drive.
USB card readers also transfer your photos from your memory card to the computer MUCH faster than from the camera.
Hope this helps.
Jan 10, 2008 | Kodak EasyShare One Digital Camera
Well mishel, its a little yes, a little no. yes you can upgrade your processor, but not all the way to 4.3ghz, with whats in your computer now, the only processors that will fit are of socket 478, its one of Intel's older chips. There faster chips to date clock in around 3.0-3.4, and that's with four cores, if you need a faster chip, you need to get another motherboard, and with your case that can be a problem. The best processor I could find was 3.0ghz and under $100 on Good Luck
Dec 11, 2007 | Dell Pentium 4, 2.26 GHz (1W391)
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
