Question about Xerox 5855C Copier
Xerox 5855C copier
The paper won't feed through at the point of exit from the copier (I'm not talking about the sheet feeder on top). If I stand at the paper exit point and grab the a paper as it appears at the exit I can pull it out. Other wise it crinkles at the point and jams.
Any thoughts.
  • 239 Answers
Yes, the exit fuser rolls do wear out. Actually they just break apart untill there is no roller there. Sometimes there might be one or two, there should be one in each slot, about 4.
Also if you are going ot take out the fuser, be very careful.
The fuser exit switch in time will crumble and fall apart. It may appear to be ok, until you actually touch it, then the plastic just falls apart. This would need to be repalced.
The fuser roll has a lot of presure on it, sometimes the fuser bearings will actually freeze stoping the fuser roll. On back of the fuser assembley are a set of gears. The small ones on the back wear and will cause the fuser roll not to drive. These are common parts that need to be replaced.
The stirpper fingers need to be checked they get a lot of wear.
At the back of the exit transport roller there are some gears and one of them has a one-way clutch check it to see if it is slipping. A touch of friction oil can help with the drive of this clutch.
This machine has a vacume fan which helps trnasport the paper on the vacume belts. This is located on the back, at the bottom middle of the machine. This fan can turn very slow at times causing false jams.
If all else fails, call Xerox for service repairs.
Posted on Oct 18, 2009
  • 3 Answers
I don't think this is your problem, you stated that you could grab the paper and pull it out of the machine. If it is jamming on the fingers then the paper would never come out far enough for you to grab it unless it is coming out crooked, meaning that maybe a finger is grabing on one end and turning the paper enough that you can get ahold on it. If I remember correctly there is a set of feed out rolls right at the exit, check to see if these are turning when making a copy, if they do not turn before the paper gets to them then check to see why they are not turning. If they are turning then make sure the idler rollers on top of the feed out roll is putting pressure on the rolls. There should be four of these, I've seen them bend and lose pressure. Hope this is helpful.
Posted on Oct 07, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
If it does like an accordion then replace the (fingers, claws, scrapers) these are the sharp claws that ride on the hot fuser roller, they are supposed to help guide the paper out, but whenthey wear out they catch it.
Posted on Oct 06, 2008
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
Button next to the button on/of flashes 3 times - still - 3 times etc
The light is the indication of a Paper feed problem,
Either the printer is out of paper:
a Load paper.
OR
b Press the Paper Feed button.
If the paper is jammed Then
Do not load too much paper in the sheet feeder. Depending on the thickness of
your paper, the sheet feeder can hold up to 100 sheets of paper or 10 mm (0.39 in.).
You do not force the paper down into the printer when you load it. For example, A4
size paper should extend above the top of the paper support. (Letter size paper
should align with the top of the paper support.) Make sure the paper support is fully
extended.
The paper guide is against the left side of the paper.
The paper guide does not cause the paper to bow in the sheet feeder.
May 02, 2011 | Lexmark JetPrinter Color Z33 InkJet
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
I have a Xerox 15i. On every sheet I print, the machine leaves a small mark/tear (1mm)on the top. Approximately 1 and 1/2 inches from the side of the sheet.
I would suspect that one of the fiser fingers has lost a spring or it is out of position.
Going form paper tray to exit, I also would look on the right side, just where the paper comes out of the paper feeder, there are some clear mylar ( plastic ) guides, inspect them for damage.
Lastly right where the paper feeds out, there are some small rommers that can pop out and cause a nick in the paper.
But more than anything I suspect a fuser finger, or even the roller baing bad.
The fuser is located inside the right door, on top. It is VERY HOT, you can remove it with the 4 silver phillips screws and inspect it.
If you need parts, google a business called " the parts drop". Give them a call, ask for Britt and they will have what you need...
Dec 20, 2008 | Xerox Office Equipment & Supplies
Paper feed on Canon i 350n ink jet printer
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
May 13, 2008 | Canon i350 InkJet Printer
I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
Apr 26, 2008 | Office Equipment & Supplies
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Ensure that:
Mar 24, 2008 | Office Equipment & Supplies
Xerox XC540 copier fails to feed bland sheet
sounds like there is something not pushing down the plunger, or may need to adjust switch to make it higher.
Oct 19, 2007 | Office Equipment & Supplies
118 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
