Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
No spin my whirlpool ultimate care II wont spin it will do everything else but spin including drain the water it will not spin in any setting. pleae help :)
  • 1 more comment
  • npbmll Oct 06, 2008
    I will put a new switch in, but the weird thing is that the switch does work the water pump in the bottom of the washer it just wont spin the cloths. to me i would thinck if the switch was out it wouldnt do anything am i wrong ?
  • npbmll Oct 07, 2008
    replaced the switch and it still wont work what do you thinck?
    i replaced the switch it still didnt work looked closer in and found that the coupler was bad. it wasnt worn all the way threw so turned it around for a temp fix and it is working atm will buy another one from sears tomorow. thanks for your help glade to now someone is out there to help. once again thanks for your time and be well.
    Novelist:
    Champion:
  • 261 Answers
I wasn't clear on the drain part, although I am sure that your lid switch is out. This is part 3949237, I will leave an photo for illustration purpose. First inspect the switch at the right side of the lid, you will see where a striker on the lid goes into the cabinet as it closes, confirm that you don't hear a click or see a firmly installed switch. Look for broken parts by reaching under and pulling on the switch as at times they come apart too.
You can see below number 11 is your switch and can be removed by two screws on the back of the console left and right corner, then pull forward and swing back. Next is the two clips left and right, #6 on the illustration. At this point there is a wire molex plug with a white, gray and green wire going into the cab that has to be unplugged. Once done the switch is held in by the two screws seen where the striker inters the cab and one 5/16 hex on the cab for the ground. The last is the two wire clips and loosing the male part of the molex plug from the cab. The rest is history.
Posted on Oct 06, 2008
  • John Robbins
    John Robbins Oct 07, 2008
    You said it did all but spin which is usually a lid switch. If it still isn't working.. is it agitating? Have you checked the coupler between the motor and gear case. This is the only other component that would go that is why I am asking more about the agitation. If it agitates but no spin then you gear case is out and maybe even a clutch/brake.
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care II will not spin or drain
The primary promlem is draining. Make sure the drain hose is not kinked or blocked .Water flowing out when the hose is lowered ( the hose needs to be lower than the water level, inside the machine as well) would show if it's blocked. Another cause is a jammed or failed pump. Good luck....Nomess
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle doesn't spin
you nead to check the door switch,nead to know the mod# to know what type of door switch you have.
Dec 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
