Question about Maytag MSD2454G Side by Side Refrigerator
MY refrigerator is running but is not getting cold.
You can tell is on the light comes on, and you can hear it get running but it does not get cold enough to keep a lot of food in it. My freezer works fine...my refrigerator is not getting cold. the freezer is working fine but the other side isnt. what do i do. how do i fix this problem. everything else seems to be working fine except for the temp.
Hi, I have GS2625 model replace 24v 10A Omron brand relay on controller board, would be all similiar across most models 'largest relay' failed 6 Mths after purchase. Inadequate circuit design better option use 15A or 20A remote mount rather than PCB.
Posted on Oct 23, 2008
  • 943 Answers
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Posted on Oct 06, 2008
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
Amana DRS2662AW Lights are on and I can hear the motor running but no cold air is coming out of vents. Freezer is defrosting. I have vacummed out coils on lower front.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana ASD2326HE Side by Side Refrigerator
The freezer light is on and you can hear it click to come on, but nothing is running or getting cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 15, 2010 | Haier Freezers
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Refridgerator has power but does not get cold
Can you tell me if you hear the compressor running under the refrigerator? Is fan running beneath the refrigerator? Need to get the exact Kenmore model number found when you open the fresh food section. Let me know, Sea Breeze
Mar 19, 2009 | Kenmore Refrigerators
Freezer does not get cold
If you open the door and the light comes on then you have power. If you don't hear the compressor motor at the back running but you hear a intermittent clicking noise coming from back there, then you have a faulty starting device for the compressor or a seized compressor motor.
http://tclaundryrepair.com/home
Feb 19, 2009 | Jenn-Air JCD2389G Side by Side...
defrost it. sounds like ice blockage. Take out freezer drawers unscrew inner back panel. In the t/l/h side there is a hole left of the fan which blows cold air that goes into fridge (side of light unit).
Use a hairdryer to dislodge/defrost this pipe. The polystyrene backing can also be moved to reveal the freezer pipes.Defrost this also. This hopefully should solve problem, if not a freezer or fridge thermistor may have to be replaced which is the coloured cable on the r/h/s of inner freezer which cost approx £20 each
Aug 26, 2008 | Refrigerators
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
448 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
