Connect a new TV . which cables?
Hi, I just got a new 32" LCD open box today from Best Buy. It has no manual and I'm having a problem connecting the satellite cables etc. Anyone with any tech help available asap ???? THANK YOU
Maureen
  • 374 Answers
Maureen,
Many TV's like yours have a two coaxial port solution. Some call them antenna A and B other digital and terrestrial. If you have these connect your 3,4 out line off the SAT box to one of them. Go to the menu on the tv and go to setup, then go to autoprgram channels and it may give you an option to scan only for one type or the other if so choose the type of signal or port that you connected sat box to and run a scan if not run it as it is and check results.
If you are connecting sat box using RCA cables ensure that they are on the output port of the sat box. Then connect the other end to one of the input port on the tv remebering what input you are conected to. Using the remote, if so equipped, cycle thru the inputs by pressing input or souce button.
If you do not have these on your remote you will need to go to menu on the tv and access the inputs that way.
If you have a VCR connected and satellite ran through it via coax you will have to go to the input source the VCR is connected to. I hope I have been of assistance to you. Thanks for using Fix Ya. If you need more help let me know.
Posted on Oct 06, 2008
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
How do i connect my directv box to my soyo tv #DYLT032D
  • If your DirecTV box supports HDTV then connect it using either an HDMI cable from the box to the TV (located on the back, labeled HDMI 1,2,3,etc.).
  • If the box is not an HDTV box then connect it with a RGB (red, green, blue) composite cable from the box to the TV.
  • If the RGB output is not on the ack of the box then connect using a standard coaxial cable.
[NOTE] In order for the quality of the picture to be HD, use the RGB for digital (Better), or the HDMI for High-def (Best)
Mar 02, 2011 | Soyo DYLT032D 32 in. LCD Television
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
We have cable T.V. should we run the cable though T.V. when we use s-video cables or use cable though vcr then T.V.
I would hope that you would use a HDMI cable to connect your cable box to your LCD TV - why not display the highest resolution to your screen that you can. HDMI will transmit the 1080P high def signal to your screen. These cables can be found at Wallmart and Target or even Best Buy. Don't need the most expensive and or a 6' length or short will work just fine.
Then use your S-Video cable to connect your VCR/DVD to your LCD TV - This is not a High Def signal - only 480i if that. The P means Progressive or 1080 lines from top to bottom. the I means Interlaced to which means 240 lines once for field one then 240 lines for field two.
You may want to think of a blue ray player to which upconverts your older DVD's to 4x3 High Def resolution.
Happy Thanksgiving and God Bless,
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Digital cable service in house.
many of the public channels were offering a coupon for a free cable conversion box... here is a LINK
Apr 19, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Open Questions:
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
