Question about Whirlpool Refrigerators
Whirlpool refrigerator 1991
The dials inside have not been changed but I noticed the milk started to freeze and now today it is making an unusual noise. Could the fridge be going out?
  • 943 Answers
Hi thanks for the question .the thermostat is at fault here . if it wasn't changed . replace the thermostat. but also, pull fridge away from the wall. remove back panel . clean all coils. thanks the appliance doc
Posted on Oct 06, 2008
I have a Whirlpool Refrigerator model # ET21PKXGW01 the freezer isn't freezing and the fridge isn't as cold as it should be (milk went bad). I did notice right before it stopped freezing/cooling I...
hey how r u today im no specialist but it sounds like a condensor fan if that fan goes your fridge will overheat not allowing proper freezing and or cooling. my family had the exact same problem and my dad was a appliance repair man so he knows about everything when it comes to this stuff..well hope i helped and congrats i hope u and your fiance go far. Jacob Winkler
Jul 16, 2012 | Refrigerators
Hi the fridge is freezing everything inside from milk to joints of meat, when you open the fridge it has a dial with numbers 1-4 n even though were not sure what number to put it at, weve tried every...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 10, 2010 | Refrigerators
Fridge not cold enough to hold milk resulting in the milk becoming sour. Fridge temperature is 10 degrees C how can we make it cooler? We have already set the temperature to the dial 7.
You could do the simple things like clean the dust and stuff around the compressor condenser. Check the condenser motor. Good air flow improves performance and cost nothing to fix. Of course if you are experiencing a defrost problem the air from below gets choke out with ice buildup around the evaporator area. If you have frost on the backside of the freezer section changes is you have a broken defrost heater.
Apr 19, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
HI: We have a 6-7 yr old TRUE single door, stainless steel fridge. We noticed yesterday ..that at "4" on the temp dial, the fridge is freezing milk in glass gallon jars. We backed the temp down to "2" and...
With the refrigerator, the fan inside the conditioned space should always run. This is normal for most all commercial refrigerators. Need to check to see if the unit is shutting off the compressor after the conditioned space reaches a good temp, usually 35 degrees. If not, probably a bad thermostat.
Apr 11, 2017 | True Food VWR Storage Refrigerators with...
Refrigerator runs too much
if set at 1 and still freezing request that they change the thermastat it is out of calabration
May 24, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator doesn't cool
Might be your condenser which removes the heat from the refrigeration system may be restricted. Clean under the unit from the front and back.
May 06, 2008 | Whirlpool Gold GB2SHDXPS Stainless Steel
Refrigerators Logo
106 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
