I have smudgy lines from top to botom aprox five right across the screen, they arnt to noticable at present. some days are more noticable than others. is the tv on its way to the dump or can it be repaired?
Hello!
your set might have 2 issues: the one is fixable, the other is not. I'd start to inspect t-con board's ribbon cables, which connect the board to display itself. In many cases, due to overheating or moisture accumulating, those connections might get unstable, what result in those intermittent lines. T-con board itself might cause this. If you won't get lucky by just reconnecting t-con's ribbon cables. Replace t-con board. It's cheapest among all signal processing. If that's not an issue, the display itself at fault. Then, you know what to do: dispose TV properly or sell it for parts in whole at Craigslist. Good luck,
Thanks,
Alex.
