I was taking pictures for my kids school program,
Every time I took a pic it showed up on the lcd monitor on the back
At home I downloaded my pics and oh surprise!
from 1917 thru 2033 pics are gone and for 2033 thru 2235 are OK,
SanDisk card was inserted again and find out a message
says: NO IMAGE FILE DATA,
I read card again using Mycomputer and get the following information
For several pictures
DsC_1535 525,342KB JPEG Image, Date modified,
Date picture taken and dimensions data does not show.
)note: file name has where I wrote_ a square character, or corchea one
Does the above mean that I lost all pictures?
If not, how could I recover them?
DESESPERATE!
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Let me tell you..it's a downhill slope from there. I had the same problem and it only gets worse. The pictures you take, the more pics on the card it will mess up. I have NEVER been able to recover any of my pictures. What I did to test if it was the card, the camera, or my pc, is buy a new card and format it inside the CAMERA BEFORE taking any new pictures. Then it was fine, as soon as I uploaded the pics to the pc they were all there as I was able to save them on my pc. The next time around, it went right back to the same old behavior deleting everything!! I learned two things the hard way. NEVER format your memory card through the pc when it asks, it messes up the settings from the card, to your camera so it causes the camera to write the pictures to the card poorly and incomplete! The other cause..check your pc if it has ANY spyware,adware, and especially a virus!!! I learned while I was uploading pics, the infection that your pc may have without you knowing, contaminates your memory card, then you're pulling it out and placing it in your camera!!! In my case, that has happened and has now corrupted the actual main programming in my camera that Nikon has set at factory settings when manufactured. Now, I'm having to send it out to Nikon to get "Re-programmed"!! =(
im having the same problem with my d70 deleting my photos at this point i gave up trying to retrieve them i just want it to stop happening
frustrated
