ELMOTOR Error from KVH TracVision L2 startup - no satelllite found
KVH L2 is mounting on a motor coach - worked fine 2 weeks ago - now will not find satellites ... symptoms follow;
With RCA receiver with low speed data port ... initializes and then give me a "ELMOTOR ERROR" - never finds a satellite + Elevation motor is moving dish between both limits with no obvious problems ...
With DirecTV receiver ... will not accept a "Restore to Factory Defaults" action (Sat Select + Power on), Power on gives 1 bright flash then 4 short dim, then 1 bright, then 5 short dim flashes -- cycles thru this 3 times then goes to sleep - never finds a satellite ...
contact me at n.v.cheney@att.net
  • Bowditch May 11, 2010
    I don't think the problem is with the receiver, but the dish which is mounted on the roof of our coach. The fact that I cannot "reset to factory defaults" when connected to the DirecTV receiver and receive the ELMOTOR ERROR when connected to the RCA receiver suggest to me that something is wrong with the KVH dish and not the receiver ... I get no signal with either receiver ...
    Do you have anyone that is familiar with the KVH L2 dish, and knows how to troubleshoot the dish if I hookup a laptop to the maintenance port?
  • 1153 Answers
SOURCE: satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Posted on Sep 04, 2007
SOURCE: X20G Fails To Power Up - Soloution Found
My monitor (SN517A1108SC1246) has same power on problem issue. This particular monitor was 'repaired' three times by Sceptre all within 4 months starting when 11 months old. The problem seems to occur when the monitor looses AC power completely so I've got mine on an UPS. The "reset" fix by MikeCharlie does work to get it back working. Key is timing, plugging in the power cord then monitor cable just after LED blinks. Tricky but can be done.
I do have another Sceptre X20 (SN505A1108SC2638) on same computer that although a year older, has not had any problems!
Posted on Jan 15, 2008
SOURCE: No FM Frequency option
unplug the tape adapter and reboot
Posted on Feb 09, 2008
tat4u
  • 520 Answers
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Posted on Mar 10, 2008
SOURCE: Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Posted on May 08, 2008
Can not locate satellite continues to search
There are few possible reasons.
Antenna can't "see" satellite.
Wrong data programmed.
Wrong skew angle.
Damaged RF board.
If you make log-file it will be much easy to understand your problem.
Jun 26, 2013 | KVH 01 0277 01sl Tracvision A7 Mobile...
How to program kvh tracvision a5 antenna to work
NEWER connect A7 reciver box to A5 dome. A5 receiver box output voltage is 32VDC, and A7 receiver box output voltage is 40VDC. So, if you connect A5 dome to A7 reciver box, you will damage it.
Jun 19, 2010 | KVH TracVision A5 Car Video Player
Tracvision A5 dish is making loud noises and is not finding satilite
Maybe you have a problem with elevation limit switch inside antenna.
Apr 15, 2010 | KVH TracVision A5 Car Video Player
What is the best marine satellite system
Intellian for ease of installation and leading edge technology. KVH seems built better, but the Korean Intellian i2 is really reliable and cheap! Plus it is a really easy install, especially for HD.
Jan 03, 2010 | KVH Tracvision M3 Satellite Tv System
Satellite Spins but can't find signal
I have a brand new A5 satellite in the box. I never used it. Are you interested in just replacing the satellite itself?
Aug 07, 2009 | KVH TracVision A5 Car Video Player
KVH M5 trouble
most likely is the coax from the dome to the receiver. Often this is intalled or terminated marginally and with age fails. Try crimping new ends on it.
May 28, 2009 | KVH Tracvision M5 With Control Panel Us...
I use to hear my tracvision a5 spinning and finding the satellite
There are two fuses on the main board in the dome, check them
Mar 30, 2009 | KVH TracVision A5 Car Video Player
238 people viewed this question
 Grubhead
Grubhead
