Mag lcd question
Hey
i read a post from you about this mag lcd saying the blank screen was caused by a bad vga controller, is that fixable, could i use a dvi cable or should i start looking for a new display?
thank you for your time,
chad
cbernard84@sc.rr.com
  • 1 more comment
  • cbernard84 Oct 06, 2008
    mag innovision LT1919WDb model: 900w
  • charlie79199 Jan 19, 2009
    Same thing as mentioned above. But its not the settings on mine. I have since bought a new monitor but im wandering if i can get parts or the same monitor for the parts. i see whats burnt up and I just don't know what its called. its black and rectangle. it has tape with typed numbers on it.Anyone have one laying around that can tell me what the part is ? there is a second one but its not burnt up like the one im touching right next to it
  • Anonymous Mar 23, 2009
    Well i picked up this monitor out of a trash pile. When i turned it on its hue was somewhat redish and then it went normal then it went blank though you can slighty see what was there before, though, it is very dark. i think it something else than the VGA controller. i plugged in when it was apart and one of these long lights that rang alond the top didn't fully illuminate. i think the wires might be looses as well, i handled it very carefully when taking it apart, but i could have done that. I didn't wear gloves when taking this apart so i have already contaminated the plasic panels and other things that would have to be cleaned before reassembly. so its gets to be added to my pile o electronic parts. But it was fun to take apart.
  • 1,498 Answers
Hey CBernard84,
While a blank screen could be caused by a controller, it could also be caused by something simple like the settings on the controller.
Question: When you boot up, does the screen show the Power On Self Test then go blank? If yes, the screen refresh rate is most likely set too high.
Comment me back, if this is the case. I can walk you through the procedure.
Hope this helps,
Mike
Posted on Oct 23, 2008
Mag monitor lt782s - green light on screen black
This means that the power supply board has a problem. The problem is that the part of the circuit that controls the backlight has failed. This is usually caused by capacitors that have gone bad or transistors that have shorted.
Dec 23, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
I have a Mag Innovisin monitor that I use with my laptop so I have a bigger screen. It will turn on but after 1 second the screen goes black. Any ideas what's causing this and if it can be fixed?
eadaniels, Could be <$10 on DIY repair if you know what a soldering iron(pencil) is used for! $40 - $80 if contract out work to local electronics tech that understands forwards and backwards common known fault conditions for CCFL back-lit LCD monitors. Read some of my fixya profile for a while. If your display had bright, crisp, colorful text and graphics displayed on it' LCD panel just moments before this black sceen, or blank n black screen problem developed you may have a shot at cheap diy repair as long as you do some research. Fixya tech's "budmrtn" and "buddymc" are two more techs that are really good!!! Let us know what your plans are after you do some reading and surfing.
12fixlouie
Mar 21, 2010 | Mag Innovision Computers & Internet
Mag Innovision LT765b 17 in. Flat Panel LCD Monitor
Hi...there,
Well, sure it fixable... but not so easy to find a AD board online. Only manufacturer carried this part... If you want you can contact them if they still have a refurbished parts laid around....
Jul 26, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
Jan 30, 2008 | Computers & Internet
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Aug 30, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Computers & Internet Logo
548 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
