My ZR60 has been sitting for some time and will no longer eject the tape. After opening the cover the enclosure come up, but the tape does not eject and the enclosure returns to the camera.
-   Same exact problem here. Was able to retrieve tape with instructions above. Seems to be an OEM problem with this model. Too bad it's outside warranty... :(
-   Guest
Dec 22, 2008
-   my camera wont eject tape either.
its completely closed and i cant even close it.
is there any solution for this or am i suppose to forget about it and get a new one?-   cibel305
Nov 01, 2008
-   I have virtually the exact same issue....
Any help would be appreciated....
Thanks
Kurt-   drbones62
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back. I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,
we bought a flip video, it works.
Please try this. I had a similar problem last few days with my ZR60. The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own. I
was messing with it a little bit and realized that the door was not
opening fully. Being a delicate item I didn't realize that I was not
fully opening the door may be because there was a little friction in
the pivot pins or what ever. Try to gently swing the door open fully and see if it helps. Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it. I was almost going to give up this camcorder last night thank GOD, I am able to use it. Good Luck to you.
I'm trying to get my mini dv tape video onto my computer so I can make my home movie dvd. Can...
(More)
I'm trying to get my mini dv tape video onto my computer so I can make my home movie dvd. Can somebody help me thru this? Not sure I have to have a software cd or if I need a certain hookup also what software do I use to to do.? Thanks Karen
the cassette carriage is stuck in the out position and the cassette is still in side. the cassette...
(More)
the cassette carriage is stuck in the out position and the cassette is still in side. the cassette carriage will not open or go in
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
