Question about Gaggenau EB290 Electric Single Oven
Won't start key symbol flashing
I'm not understanding instructions or steps to start. Purchased years ago damaged in show room, door replaced right front corner, bottom of oven smashed in. Inspection completed by tech after repair no inside damage found.
Display shows all functions mode changes (key symbol flashing) child lock symbol out.
  • somedayillco Oct 06, 2008
    oven first time starting, read manual all modes displayed and appears normal other than flashing key symbol not child lock symbol.Holiday program stuck waited 12 hours still flashing.Removed power for reset. Key symbol still flashing
    Scholar:
  • 116 Answers
1. Press the clock key 3 times until the hr/min icon flash.
2. Press the + or - key until you come to your desired time.
3. Press the confirmation (key or tick) key.
Posted on Oct 06, 2008
    Genius:
  • 1,550 Answers
So do you need a manual for operating it ?
  • SAM ANDERSON Oct 06, 2008
    The child and vacation lock should be automatically activated and oven should switch off within 12 hours if this does not happen there is some fault with the oven . Mostly timer is not working properly .
    President:
  • 1,952 Answers
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
F5 E1 error. Oven door won't open after running cleaning cycle
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
F5 - E1
Feb 21, 2011 | Whirlpool RBS275PD Electric Single Oven
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
E1 -F5- Error code appears when attempting to start self-cleaning mode.
F5
- E1 Self clean latch will not
lock
1.
If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 04, 2010 | Whirlpool RBS275PD Electric Single Oven
Door lock symbol flashes all the time
this may not be very helpful Gaggenau can be really tricky
ive seen this once before a long time ago but its worth a shot
the connection from the lock sensor might be loose
you should be able to unscrew the control and roll it up
right behind it you will see the lock and connections
jiggle em
like i said a long time but i believe the connection on the control board is green
Oct 07, 2009 | Ovens
FSE7 appears on kitchenaid built in oven
Here is the fault code for F5:E7...
1. If door latched:
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Sep 16, 2009 | KitchenAid Ovens
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
4. Re-apply power.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
Code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
Gaggenau EB290 Electric Single Oven Logo
809 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Shehu Pro
Shehu Pro
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
