Top loading roper washer stops at spin cycle - Washing Machines
  • christina lessard Mar 17, 2009
    after the wash cycle it stops right before the spin cycle and won't continue the rest of the cycles.
  • FLIZ Mar 20, 2009
    located under the top where? what does it look like? please more info.
    thanks,
  • 943 Answers
HI thanks for the question. the washers lid switch, is the problem. replace the lid switch. its located under the top.if you need more info. get back to me. thanks the appliance doc
Posted on Oct 06, 2008
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
Washer stops after wash cycle. Won't empty water, won't spin.
the lid switch is defective or the lid or door screws on left & right side are loose tighten and or replace. nbcrca:)
Apr 11, 2009 | Roper RAS8244KQ Top Load Washer
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Maytag Atlantis Top Loading Washer stops after wash cycle
Sound like a bad Brake & Drive Tube sorry to hear that it is not easy but you can fix it..
Aug 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
