Question about Frigidaire GLWS1339CS Top Load Washer
Smoking burning rubber smell from machine
Frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
  • Ellie414 Feb 10, 2009
    I have same problem after water came out of the bottom of machine last night, we opened the front and could not find any leaking by the hoses. We put it through a wash cycle and it began to smell like rubber burning. we stopped the cycle and emptied the water but we saw it leaking above the tub and down the back. Is this machine shot? Should we call a mechanic or go to Lowes for a new washing machine?
    Please help.
    Thanks.
  • Anonymous Mar 22, 2014
    Washing machine Bosch WAA24163SN started producing a chemical smell, and last load was producing smoke as well. Had to stop the load.
  • 750 Answers
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Posted on Oct 06, 2008
Smell of burning rubber and smoke from drawer
Sounds like your drive belt is loose or worn out. You will probably need a new belt. Is it possible something got inside the machine and jammed the belt?
Dec 12, 2014 | Hoover Washing Machines
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
My calypsal washer smells like burning electrica or rubber in the spi mode
The motor could be leaking oil. Pull the machine out and look for stains or puddles on the floor.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
My Frigidaire Washer began pouring out smoke. Smelled like burnt rubber and the smoke from the garage filled my home. Had to call out fire department. not an electrical issue
The bearing on the main spindle probably seized and the motor continued running and burned up the belt. The belt will need to be replaced, and whatever caused the issue in the first place will need to be remedied weather it was a bearing or something else.
Mar 22, 2012 | Frigidaire GLET1142CS Top Load Stacked...
Smells like rubber burning and then the machine starting smoking...
probably the belt . Make sure the tub is turning freely . If not check for nail in one of the holes or an article of clothes jammed between tubs. If it turns freely just change the belt
Oct 29, 2010 | Frigidaire GLWS1339CS Top Load Washer
I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type...
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Sep 05, 2010 | GE WBVH6240F Front Load Washer
Washer was pouring out smoke and smelled liked burnt rubber
You most likelyhave burned a drive belt. Could be a couple things. If the machine was loaded to the max and a bit more, it is possible that a small article of clothes may have been flung into the outer tub and into the pump... this can freeze it up and the motor will keep trying to turn the belt against a frozen pulley.
You'll need to open the machine and check the pump for blockage and change the belt... let us know if we can help with procedures..
k
Jun 25, 2009 | Frigidaire FWSB5700DS Top Load Washer
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire GLWS1339CS Top Load Washer Logo
2,349 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
