Question about Dremel Tools & Hardware - Others
Dremel belt/disc sander
Cannot run sander without breaking the belt.  Tried adjusting belt tension, but not sure how to adjust it so belt doesn't break a few seconds after turning on the machine.  Belt was adjusted so that it did not run off the pulleys, so this is not the cause.
  • Anonymous Mar 19, 2014
    Keep putting belt on and belt comes apart where it's glued. I'm thinking maybe it's the glue
  • 29 Answers
See the manual
Posted on Nov 06, 2008
  • clydelascruc Dec 20, 2010
    If I had the manual I would read it.
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
Can the tracking on the sanding belt on the B&D belt sander 5.2A be adjusted?
yes ther should be a knob on the top front roller (top side) this should affect tracking , also make sure tension taker (lever for changing belt) Is fully off so that belt gets its full tension , if the belt doesnt get full tension it will walk side to side
Sep 22, 2014 | Tools & Hardware - Others
How do I adjust the drive belt tension on a nu-tool NT46-4 disc and belt sander
Look under the machine.If there any plate unscrew them and there you will find the belt.I never use one of this brand but usually with a couple of nut / screws you can adjust it.
Nov 05, 2011 | Tools & Hardware - Others
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Jun 13, 2011 | Black & Decker Garden
Craftsman 315.117150. The belt keeps sliding off, as soon as turned on and start to sand. It seems to be on correctly.
You need to adjust the tracking knob which is by the front handle that looks like a triangle head screw. Make sure the belt tension leaver is tight and the belt has enough tension on it. Quickly press and release the start switch and note the centering of the belt. It should be in the center of the bottom platen. If it is not, adjust the tracking knob and bump the switch again. If the belt is going in the wrong direction turn the knob the other direction. Once you are close the center of the platen, press the power switch to turn the unit on and lock the trigger. Firmly hold the unit vertically from the front handle. Fine adjust the tension knob to center the belt and make sure the belt is not hitting the case which will cause damage. You should be able to use the belt sander without the belt slipping off. Let the sander do the work, do not push down and limit the side to side motion. If the belt will not stay on then the belt is too large or the torsion spring needs to be adjusted to applying more tension on the belt and drive roller.
Mar 22, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
How do I change the sanding belt on my 7447 belt sander
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
BELT SANDER ADJUSTMENT
Try removing the adjustment screws and applying some Teflon thread sealant. That should prevent the screws from turning on their own. Another thing you can do it check the pulleys with calipers and make sure it is still cylindrical. I have seen ones that become worn on one side. Finally, roughly check the belt tension on both sides and make sure they are approximately the same tension.
Good Luck!
Ben Steigerwald
Jan 11, 2009 | Tools & Hardware - Others
Belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Sep 15, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
860 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
