I have Sony DSC T7 and when i opened the screen got stuck to "Clock Set" menu. please help
SOURCE: reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
SOURCE: Sony Cybershot DSC-T7
Hey lmcconnell,
Error code E:61:00 means the camera has encountered a malfunction, and you should try initializing the camera back to the factory settings. Instructions on how to do this are on page 51 of your user manual, and I have included a link to a PDF download of your manual if you no longer have it. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT7
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
SOURCE: sony cybershot dsc - t7. the display says ''lens cover closed''
It appears that you have already tried what I'd have suggested as a last resort. Apart from cleaning the contacts and removing the battery for 15 minutes there is not much that can be done.
In my opinion it is better to purchase new camera than to spend so much on this one. Note that sony may also charge you a checking fee if you decide to send the camera in hope for less costly repair than they estimated.
And yes, it would be fruitless to dismantle the camera if you are not qualified for this stuff. There are no user serviceable parts inside and also there are timed mechanical switches which can be difficult to reassemble without a proper schematic.
PS. Please do not use Vodka for cleaning electronic components as it contains small amount of moisture. Use Isopropyl alcohol.
Hey,
I've got the same problem!
If you've got it fixed, could you please tell me how?
Thanks in advance
