Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony S350 Blu Ray does not work
Just hooked up a KDL52W4100 to Sony S350 Blu Ray via 1.3 HDMI cable. The TV does not detect the Blu Ray regularly (actually, its only worked twice.) Otherwise it says the device is not detected although it appears on the TV as HDMI 3.
  • BriDu Oct 06, 2008
    Great suggestion. I should have considered this myself, but the problem was intermittent. To check it, I pulled the other HDMI cable out of my Comcast box that works fine and plugged it into the Blu Ray and it, too, now works fine. I'll replece the faulty cable.
    Thanks for your help.
    Genius:
  • Sony Master
  • 1,148 Answers
That could be a faulty hdmi cable,,ive had that happen
Posted on Oct 06, 2008
HOW TO CONNECT A SONY BLURAY PLAYER BDP-S350 TO MY LG TV
One single HDMI cable will be enough, it will carry both the video and audio signals.
Jun 18, 2010 | Sony BDP-S350 Blu-Ray Player
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Dec 27, 2009 | Sony BDP-S360 DVD Player
HDMI not working Sony BDP-S350
plug the sony player into your home network via a network cable ( should be a network port ( RJ45 port ) on the back of it and then update the firmware - unless its already the latest version, if it is then post back with any error messages or whats happening exactly when you try to select HDMI or is it greyed out ?
Jun 02, 2009 | Sony BDP-S350 Blu-Ray Player
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
With sony products sometimes you have to use sony parts to get it to work. I would suggest to buy a sony HDMI cable and see what happens if that doesn't work then take the player back to the store because you got a faulty player.
Jan 08, 2009 | Sony BDP-S350 Blu-Ray Player
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
172 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
