Question about Cameras
Inserted the disk for my Canon A470 into my computer. Got the message "screen resolution to execute Digital Camera Solution Disk is not sufficient." I realize it's not a camera problem but not much I can do in the way of downloading since not even the disk provided suggests what to do.
  • tarrbri Mar 23, 2009
    I'm trying to install onto a netbook, and the resolution on this only goes up to 1024 x 600. is there a way around this?
  • 2,104 Answers
You have to set the resolution on your computer's monitor to the minimum required to run the software. To do this, go to your desktop (no programs showing) and right click in an empty area on the desktop. Go down to "Properties" on the menu that appears and click on it. Look along the top of the window that opens for a tab named "Settings" and click on it. You should see an option (usually on the left) to change your screen resolution. Change your resolution to the minimum required for the program. Depending on your computer, you may be asked to confirm the new settings, or you may have to restart your computer (the computer will tell you). Once you have the new screen resolution set, things will appear to be smaller on the monitor, but you will be able to see more of whatever you are looking at.
Posted on Oct 06, 2008
I purchased a new laptop and it will not read the canon a570is disk. it gives me an error stating "the screen resolution to execute digital camera solution disk is not sufficient." help
No need to attention for it,just go on ,I have happen to this problem like this for several model of cameras,but it is just a OS mislead error sometime.By the way,confirm your battery for Canon PowerShot A570 IS is installed.
Nov 22, 2010 | Canon PowerShot A570 IS Digital Camera
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
The installation disk is not working
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 03, 2009 | Canon PowerShot A470 Digital Camera
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Can't install the solution disk
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
212 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
