Washer leaks under tub - Washing Machines
  • LKAT65 Nov 19, 2008
    My Amana LW8203 washer has a leak under the tub. Water drips down onto the tub hub, and when it is in spin cycle the water is sprayed all over the outside walls of the washer at the height of the hub. It therefore is not the seal between the hub and tub as far as I can tell because the water first sits in the little recesses of the top part of the tub-hub. I can actually see the water coming from above that. Funny though, when the tub is first filled, it does not appear to leak until after it starts the wash cycle.
    Novelist:
    Champion:
  • 261 Answers
Can you see exactly where the water is coming from? When the machine is spinning and you lift the lid does it stop in less than four seconds? Does the water come from the side of the tub near an area where a tube attaches? Is there water staining down the side of the tub and an area near the top shows leaking? Is there rust and oil stains at the base of the gear case? Please blog back, SearsTechToo.
Posted on Oct 06, 2008
My he3t washer when water goes in tub it leaks
most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
Oct 25, 2009 | Kenmore HE3T Washer
Roper top loading washer RTW444OVQ leaking when filling during washand rinse cycle what do we do
You will need to remove the washer exterior cabinet in order to sufficiently locate the source of your leak. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
The pump and drain hoses connections are located in the FRONT of the washer directly under the wash tub.
The water inlet and dispenser hoses are located along the back.
To get the cabinet back on the washer, follow these steps:
1, With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Some other things to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the are UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak. Read through everything thoroughly before beginning any repairs. I hope this information is helpful.
Aug 21, 2009 | Washing Machines
Leaking tub in front
If this is a Whirpool toploader and it is leaking from the front, this is commonly caused by a damaged drain pump. These pumps are sealed units and are not serviceable. So, if it IS leaking, the pump must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
Of course, the real determination will be exposing the internal components of the washer to get a better view. The link provided has all the steps required for removing the washer casing to expose the internal components. This will give you a better idea in determing where exactly the source of the leak may be coming from.
Run a small amount of water in the tub before you unplug the lid switch connector. The washer will not run with the lid switch disconnected, so you will need some water in the tub to see where your leak may be.
The drain pump is located in the front of the washer directly below the wash tub. Check the drain hose connections and the pump housing. As stated before, if the pump is leaking it must be replaced. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Check the wash tub for any cracks as well, followed by a check under the center potion of the tub. If the leak is along the wash tub any where, the tub may have to replaced. If the leak is coming from UNDER the tub, you may have a leaky tub seal. These repairs are not difficult, but are labor intensive. We'll cross that bridge if needed.
Read through the link and let me know if you have any questions. I hope this helps you.
Aug 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking water at the bottom. Can this be repaired?
Have you checked the drain pump? These washers are notorious for developing leaks with the pump. To inspect thoroughly, you will need to remove the exterior case of the washer. Just follow these steps:
Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. The pumps can develop small cracks and begin to leak. If this is the case, the pumps are not serviceable and must be replaced.
Check the tub seal. The seal in the center of the wash tub. If the seal develops leaks, you will notice water track marks on the transmission and a puddle under the center of the wash tub.
Check the the for cracks. Although it is not common, I have seen stress cracks develop on the exterior wash tub, causing leaks. The tub will have to replaced if this is the case.
Check the air dome hose to make sure it is still attached and not leaking. It is a small plastic hose that runs from the pressure switch in the console to the lower right hand side of the wash tub. If the hose comes loose of develops leaks, the washer will begin to leak as it fills (usually about 1/3 of the way full).
To reinstall the case, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
NOTE: Run some water in the tub about 1/3 of the way full BEFORE you remove the exterior washer case. That way you can check for any leaks with water in the tub. Let me know what you fins. I hope this helps you.
May 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking from underneath. Doesn't appear to be the incoming hoses or connections or the drain.
May 04, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
268 people viewed this question
Top Washing Machines Experts
