Question about Apple iPod nano
My ipod will not light up... but it is charged. and i have tried to reset it. what else could be wrong?
    Guru:
  • 158 Answers
If it won't turn, is what you mean I can help. I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I'm sorry if you meant, that your ipod would turn on, but your backlight wouldn't work. If this was the case, I'm sorry I can''t help you. Sorry if I wasted your time. I hope this helps. Please rate my solution.
Posted on Dec 04, 2008
  • Apple Master
  • 6,487 Answers
When an Ipod wont power On the first thing to check here is the battery because if the Ipod is charge and still wont power ON it only means the battery is bad already and needs a replacement and if your Ipod is still under warranty the battery replacement is cover by the warranty so just take it to a Apple center and let them replace the battery....
Hope that helps.........
Posted on Oct 06, 2008
The ipod will not charge nor work when docked, yet the radio works. The ipod will charge on a computer or wall charger. what's wrong with the docking part?
I just tried calling the company....what a joke that was...anyway, there is a reset button on the bottom of the radio.....you can press the reset button with something like a paperclip. This should reset your settings and hopefully start to charge the iPod while docked.
Aug 21, 2010 | Digital Products International Clok Smooth...
I have two ipod video's a1099 and a1059, They were dead wont turn on wont charg,, I got two new battery's The a1099 came on with new battery and had about 1/2 a charge, charged it last night just...
Hi, answer a little bitlong, you can use this links to reset the ipod.
reset-ipod.com/reset-ipod-video.htm
or
support.apple.com/kb/ht1339
or
wikihow.com/Reset-an-iPod
or
support.apple.com/kb/ht1320.
Hope it helped. await your comment.
Take care.
Jun 06, 2010 | Audio Players & Recorders
Ipod does not charge after plugging in ac adaptor for 8 hours
Is it an official Apple charger? A lot of 3rd party chargers have this problem, they work fine for a while and suddenly stop working. I would try plugging it into the computer, if that doesn't charge it then something could be wrong with the ipod. If it doesn't charger google "reset ipod" and follow the instructions provided by Apple.
Hope this helps!
Tim
Jun 27, 2009 | BoxWave Corporation Apple iPod 3G (20GB)...
Itunes won't detected my ipod,
did you try to reset itunes to default
Jun 21, 2009 | Apple iPod nano
Ipod not responding
You may be doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps you!
Apr 18, 2009 | Apple iPod nano
Ipod nanao 2 gb problem
Have you tried plugging it into your computer and restoring the programming? Also, you can try pressing the menu and the center button at the same time for 10 seconds. It should go black (turn off) and then turn back on with the Apple logo. If this doesn't fix your problem, you got something wrong with the hardware, not software.
Jan 19, 2009 | Apple iPod nano MP3 Player
New pink apple ipod shuffle
Nothing is wrong you are supposed to let the ipod shufle charge a day after you buy it
now if you charge it again it would probably turn green.
Dec 20, 2008 | Apple iPod shuffle MP3 Player
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
79 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
