Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp officejet 6110
Printer works but scanner gets error message "could not be initialized because it was not found " i can see and work on pictures previously scanned in the hp photogallery. the scanner is 4 years old.
thanks much !
sincerely ... fnt
  • 13027ave Oct 06, 2008
    Scanner failure. Turn off then on again.
    Now it won't let me print
  • msmaniac May 11, 2010
    Is this the exact message that u are getting on the computer? can you please tell the exact message so that it would be easier for me (or anyone) to get a clear understanding of u r issue.
    thx
    Scholar:
  • 105 Answers
Assuming that your OS is Vista, here are the steps that may help you resolve your issue.
Posted on Oct 06, 2008
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Want to buy HP6110 OFFICEJET
I have a HP OfficeJet 6110 that I'm willing to sell. It is having the "Right Cartridge Incorrect" error described earlier in this this thread, and I haven't found the right fix for it yet. Worked just fine up to now.
Oct 25, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
After putting it on, does not continue starting.
if the scanner is the problem, scrap printer...sorry!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner part of my system quit working.
Hi
I understand the issue, many HP all in one printer can print, but they don't scan. you might a error message "Error occurred while communicating to scanner device..". Before we uninstall the software, we can try resetting the USB composite Devices.Just follow the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP OFFICEJET 6100.
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Please response after trying this.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 all in one scanning
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
