thanks , but where is the blower resistor located , i know very little about carsthanks , but where is the blower resistor located , i know very little about cars
usually in the housing near the blower motor.http://www.thepartsbin.com/includes/secu...usually in the housing near the blower motor. http://www.thepartsbin.com/includes/secure/popup.php?type=more&image=aHR0cDovL3d3dy50aGVwYXJ0c2Jpbi5jb20vY2F0YWxvZy9pbWFnZXMvcHJvZGltYWdlL2ltYWdlcy9XT1JMRFBBQy9XMDEzMzE2MTAwMzJPRVMuSlBH&title=T0VTIEdlbnVpbmUgQmxvd2VyIE1vdG9yIFJlc2lzdG9y&text=PGI+PC9iPg==
You can't post conmments that contain an email address.
The most common reasons an INFINITI I35 heater isn't working are a broken heater blower motor, a problem with the thermostat, or a failed heater blower motor resistor.
sounds like you need a new blower resistor, its under the dash on pass. side. if it goes bad your blower will only work on high. its fairly easy to change
SOUNDS LIKE THE SWITCH & OR THE BLOWER MOTOR RESISTOR, ARE THE PROBLEM WITH THE LOWER SPEEDS. SPEED 5 MAY HAVE ITS OWN FUSE, REFER TO OWNERS MANUAL FOR INFORMATION ABOUT THE HEATER/AC FUSE.
You may have a faulty fan switch. Had mine replaced when only #1 and #4 were working and it fixed the problem. Unfortunately, there may be more issues, as a year later the switch is failing again. May be some kind of feedback that is causing it to fail.
Hey,
I'll assume for now that the blower motor is working.
Now, there are a couple of things things to check.
1. Easiest thing to check is the coolant level. If the coolant is low, your heater will not give any warm air. Hopefully this is the problem as it's the easiest fix.
2. The thermostat. When the engine and coolant are hot, your top rad hose should be hot as well. See if the rad hose is hot to the touch. If it isn't, your thermostat might be faulty. It's a fairly easy and cheap fix as well.
Good luck.
